Old 06-17-2011, 02:04 PM
BudMcGregor BudMcGregor is offline
Question 2001 Cavalier instrument cluster lights
I replaced my broken instrument cluster with one I got at a junk yard. The 'new' one has the LED indicators working but the incandescent ones don't light up. I checked the fuses in the fusebox on the dash and all appear to be OK. Can anyone tell me if there is a fuse or some other replaceable component somewhere else? Thanks in advance.
Old 06-25-2011, 09:43 AM
orkel orkel is offline
Re: 2001 Cavalier instrument cluster lights
I take it be incandescent ones, you mean the dash lights.
I had the same problem, and did the same thing you did. The replacement I got from the junk yard had only one side of instrument panel being lit. I took it back, and they replaced it for free.
Seems the illumination lights are hard wired in to the cluster, and can only be changed with great difficulty. The yard told me that this was a common problem with these cars, and they do not usually sell these clusters because of this.
I would take it back and have it replaced
Old 06-25-2011, 10:32 AM
jdl jdl is offline
At the instrument cluster connector, gray wire is voltage, black wire is ground. Use a voltage tester. Also, the radio/instrument lamp fuse, should be hot all the time.
Because the bcm sends voltage for the instrument illumination, there might be a trouble code? Have the codes checked.
92 cavalier instrument cluster burning out? do it myself often Cavalier Problem Diagnosis 0 01-01-2011 10:23 AM
2001 Passat Instrument Cluster Ryannables '97+ 1 06-15-2009 09:10 PM
'99 GP/GT Instrument Cluster Problem USARet1995 Grand Prix 6 04-21-2009 09:47 PM
2001 Cavalier hizkid42 Cavalier Problem Diagnosis 2 03-07-2009 08:20 AM
96 Cavalier instrument cluster issue. brown1911 Cavalier Problem Diagnosis 0 04-05-2008 02:39 PM
