Old 06-15-2011, 09:52 PM
MikeS144 MikeS144 is offline
Overheating! Gah!!!
I've got a 94 Cavalier with close to 200,000 miles on it. It recently started to run warmer than I would like for it to. I can run the heater and it brings the temp down to the middle mark but most of the time it hangs around the 3rd mark or higher. I was thinking radiator but after swapping in a new one today I'm in the same boat. I have also swapped out the stat. What am I missing? I flushed the radiator before replacing it and I am getting flow from the pump. I also figure that if the heater works the water pump works. I'm I running in the right direction?
94 Safari 203000 miles
94 metro 310000 miles
Old 06-16-2011, 08:57 PM
Re: Overheating! Gah!!!
UPDATE!! I pulled the new T-stat and ran it with out it. The temp is staying down where it is supposed to. I tested both the new and old stat with a thermometer and boiling water. They both opened at the same time, right around 195-200. I know this is not a permanent fix, but what else could be causing this?
99 xj overheating 99XXXJ Cherokee 4 12-03-2009 07:35 PM
Overheating pineapple0123 Caravan | Voyager 3 09-02-2009 05:56 AM
my 1997 dodge neon keeps overheating Lavette General Discussion 2 08-23-2009 06:15 PM
1999 contour overhating thermostat has been changed madd802 Contour 4 08-15-2009 08:42 AM
03 Alero overheating/puttering Grizzly5421 Alero 5 08-13-2009 05:44 PM
