Old 08-31-2009, 05:15 PM
pineapple0123 pineapple0123 is offline
Unhappy Overheating
If there is debris in the cooling system where would it collect? The car keeps overheating and there is a brand new radiator, thermostat, and water pump. It also only really overheats when the airconditioning is on. Would a collection of debris cause this?
Thank You
Old 08-31-2009, 06:18 PM
Bear Bear is offline
Re: Overheating
Are the cooling fans running when the AC is on, if not it could be a bad fan relay.
Old 09-02-2009, 03:32 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Overheating
I would think debrie would get caught in the radiator and especially in the individual vane openings. Check your cooling fans.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 09-02-2009, 05:56 AM
rzramon rzramon is offline
Banned
Re: Overheating
Hi pineapple,
I can understand your pain of Car's overheating problem, even i too had gone with the similar situation. Over heating mainly occurs due to improper functioning of antifreeze component which is installed in your car. If you find your cars is facing the leaking while parking then get alter, these are the symptoms of your antifreeze system's improper functioning. So i do advice you to kindly get updated with your things.
Regards,
Razor
Tags
overheating
