Go Back   Automotive Forums Car Chat > Ford > Contour
Old 08-11-2009, 03:09 PM
madd802 madd802 is offline
1999 contour overhating thermostat has been changed
1999 contour with a v6 overheats when u drive for a very short period of time the thermostat has been changed and its full of anti freeze it has 176,000 miles just not sure what else to do ? any help would be awsome
Old 08-11-2009, 03:15 PM
SUPERDAVE22 SUPERDAVE22 is offline
Re: 1999 contour overhating thermostat has been changed
Take off coolant cap(when not hot)and run see if u can tell if there is a flow. Coolant level should drop when thermostat opens. Could have air in system, or bad waterpump. IF COOLANT IS MOVING YOU MAY HAVE A COOLING FAN ISSUE
Old 08-14-2009, 01:16 PM
the fan is kicking on but ill try to c if the antifreeze goes down when the thermostat kick in when we replace the thermostat we put the old one in boiling water to c if it opened and closed and it did so the thermostat was no bad
Old 08-14-2009, 05:01 PM
bruce24444 bruce24444 is offline
I had the same problem with my girlfriends car. The fan would cut in but it would still get hot and then it would either stall or be very sluggish.
I changed the fan temp control switch and the engine temp gauge and it seems to be working better but still have a a minor overheating issue on really hot days.
You should also see if there is a bunch of dirt and bugs stuck between the tranny cooler and the radiator. I blew this out from the bottom and you wouldn't believe the crap that came out.
Old 08-15-2009, 08:42 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Well my 98 v6 doesn't heat up but my light for the coolant stay constanly on.
  • Water pump belt snapped
  • Caused my coolant reseroir to break
  • Caused car to overheat
  • I had to replace the thermostat, tempature sensor, reservoir, and belt.
Light turned back off for about a week and came back on after that. It will turn off sometimes after driving for 5 minutes. Any ideas
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Tags
contour , overheating
