Old 06-15-2011, 10:32 AM
Solonys Solonys is offline
auto headlight problem not ignition switch
My automatic headlights stopped working a bit ago. I replaced the ignition switch and checked the fuses but no go. I can't seem to find if there is a relay I should replace that is specifically for the auto headlights, does anyone know? Headlights work normally if I turn them on manually.
Thanks in advance!
Old 06-15-2011, 11:37 AM
pfofit pfofit is offline
Re: auto headlight problem not ignition switch
The auto headlamp relay is behind the glove box at one end of a row of 4 or 5 relays.
It will be the one with two yellow wires going to it as well as a black, an orange and a pink/white wires.
The light sensor on the dash sends a signal to the BCM that it turns activates this relay that bypasses/simulates the stalk switch.
If it was easy, then anyone could do it.
Old 08-30-2011, 01:18 PM
I replaced this relay and the auto headlights still do not work. The sensor appears to be good; when I pull the car into a parking garage the dash lights up and the radio dims like it is supposed to.
Not Starting, did ignition switch - no help Royalwapiti Intrigue 10 02-10-2010 01:37 PM
Ignition Switch mb8668 Eighty Eight 9 11-01-2009 08:41 AM
94 digital dash & auto headlight problems mikepmd Caprice 2 10-26-2007 02:38 PM
No power to Fuel Pump. NOT IGNITION SWITCH coltsfanjoe Blazer 2 09-06-2006 02:39 PM
Auto Headlight Delay not always working Brently Grand Cherokee | Grand Cherokee SRT8 0 10-24-2004 06:43 PM
