Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-12-2011, 01:30 AM
cjstew4 cjstew4 is offline
94 Camry radiator doesn't pull coolant from overflow tank
Why would the radiator in my 94 LE (247k mi) not pull coolant back into it from the overflow tank. Every few months I have to add about 20 ounces of coolant to the radiator. Hoses from radiator to overflow tank and one small one off the overflow tank are clean, no blockage, and when presurrized, will not leak air. My radiator cap is pretty old but seems to not leak, etc. Should I replace it anyway or could the problem be somewhere else?
Old 06-12-2011, 01:21 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 94 Camry radiator doesn't pull coolant from overflow tank
I would replace the radiator cap with one from Toyota so that you are sure you get the correct pressure. They are not that expensive you have to take a chance with an aftermarket one.
When you said that "when presurrized, will not leak air.", did you mean the overflow tank and hoses or the entire cooling system. If you haven't checked the cooling system, do so. There may be a leak there. Still, the most likely cause is the radiator cap.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 06-12-2011, 01:44 PM
danielsatur danielsatur is offline
I agree, it sounds like a bad cap that can't vacuum the coolant during cool down period.
Old 06-12-2011, 10:19 PM
Thanks. I pressurized just the hoses to/from the overflow tank and tank and no leaks, blockage. I will try a new rad cap though. I did have a total shutdown from an overheat and total loss of coolant from my waterpump/timing belt area about 35k mi ago. Although my mechanic did replace the waterpump, timing belt, and t-stat he did say that I may have caused irreversable damge to the heads, other components that may get worse in a few months or a few years. I think I may be knocking on that door now. Hopefully the cap does the trick. If not, I wil get the whole cooling system pressure tested.
3100 v6 leaking coolant from timing chain gasket? jamc204 Grand Prix 4 06-22-2010 11:18 AM
Antifreeze Disappearing From Overflow Tank MPraz Explorer | Explorer Sport Trac 7 10-15-2009 02:20 PM
Coolant not returning to rad from overflow tank 96tsport Trans Sport 4 12-31-2008 09:52 PM
98 7.4L Crew Cab Dually losing coolant into overflow tank? flash12 C/K 1 12-22-2008 03:59 PM
94 grand am spewing coolant from overflow tank sirofsirs Grand AM 6 05-11-2006 11:51 AM
