Old 06-11-2011, 07:20 PM
pb4007's Avatar
pb4007 pb4007 is offline
Ferrari 612 Scaglietti
Hey fellows. I'm taking on a new project and my first Ferrari It's a Revell of Germany Ferrari 612 Scaglietti. They started producing these cars in 2004, and it was actually designed to replace the smaller Ferrari 456, which was stopped in production in 2003. The design of this car traces a little to the 1954 Ferrari 375 MM, especially for its headlights. The "612" in the name stands for a 6 liter, 12 cylinder engine, which gets the car to up to 196 mph. Scaglietti, is the name of a designer Sergio Scaglietti, who founded Carrozzeria Scaglietti as a car repair shop, and was couple blocks from Ferrari in Maranello. Then he gained trust of Enzo, and designed some of the world's best Ferraris such as the 1957 250 California Spider, 1958 250 Testa Rossa, 1962 250 GTO and more.
Ok, so I started with the body. It was fairly well, some minor mold lines above the tail lights and around each of the side windows. A bunch of mold circles inside the body, so you have to make sure to take care of those too.
I decided to make this one Nero (or black), so I laid a coat of gray primer to make sure of any missed mold lines etc.. Sanded those down and sprayed another coat of gray.
I was a little disappointed with hinges for the hood. First off, it does not fit on the hood at all, nor does the part fit on the body...So you can try using super glue to make it work, or make your own. I will be making my own hinges. However, the hood fits perfectly to the body!
Also, I test-fitted the back bumper, doesn't look like there is trouble with that.
Finally I primed most of the body color parts (the body, the hood, the back bumper, the mirrors), still have the head lights to go, but they're chrome and require stripping. Test fitted all the parts in parentheses.
Then I got to the wheels, they're in chrome which is a no no
So I stripped the chrome off....
And whoila! The wheels are done. I sprayed them with Testors Aluminum Metalizer, clear coated, placed on the Ferrari logos, and clear coated again
That's it for now. The PE parts are still on its way to me from UK so once I get those, hopefully I'll get a chance to start working on the engine. Top of the day to you guys.
Old 06-11-2011, 09:04 PM
countach79's Avatar
countach79 countach79 is offline
Re: Ferrari 612 Scaglietti
awesome start!
the wheels turned out fantastic!!
Old 06-12-2011, 08:22 AM
BVC500 BVC500 is offline
nice start!
Old 06-12-2011, 10:42 AM
MidMazar's Avatar
MidMazar MidMazar is offline
Nice progress, and the wheels look a lot better.
In Progress
Old 06-12-2011, 09:04 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
Great start!
I'm interested in the PE set as i've been thinking about adding a set to my build.
SCCA 7, The lost Z
Old 06-13-2011, 04:22 PM
alviga69 alviga69 is offline
i have a quetion, what did you use to clear coat?, Gloss clear coat or semigloss?
looks very realistic
Cheers
Old 06-13-2011, 07:16 PM
da_ashman's Avatar
Great work so far!
Old 06-13-2011, 11:09 PM
pb4007's Avatar
Thanks guys. I haven't gotten the PE set yet so I can do much on the car. But today I got the dashboard painted, tomorrow I will detail it and upload some pics.
Thanks. I used gloss clear coat
I might be the youngest modeller on here, only 14, but I will accept your criticism as if I was older
Old 06-14-2011, 01:32 PM
pb4007's Avatar
Time to go for vacation so I won't be building this one for a while, but I will post some pictures when I get some progress
Old 07-17-2011, 01:57 PM
pb4007's Avatar
Okay guys, I'm back from vacation so I didn't wait and painted the body black. It's my first experience with enamels but I like lacquers a bit more. I sprayed three mist coats last week, then I waited 24 hours to dry and I sprayed the first wet coat. Then I set it off for 3 days to put the last wet coat which was yesterday and today I took couple pics of the body. The paint left some sort of texture to it, but I hope after 9 more days of waiting the rubbing compound and wax will do it's trick.
Question. Can I use the rubbing compound and wax without applying clear coat? And also, will it harm the body if I use automotive rubbing compound and wax on enamels?
The NEW Ferrari 612 Scaglietti!! assman!!! 456 | 550 | 575 12 06-01-2005 12:26 PM
Review : Ferrari 612 Scaglietti (Revell Germany) Many PICS bigfrit Car Modeling 18 03-16-2005 09:35 AM
Ferrari 612 Scaglietti cfcrules Car Modeling 1 03-13-2005 09:03 AM
Ferrari 612 Scaglietti jayjayjayjay General Discussion 9 05-07-2004 04:18 PM
The new Ferrari 612 Scaglietti needs its own Sub-Forum under Ferrari rahulchand General Discussion 6 12-28-2003 04:40 PM
