Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 06-10-2011, 09:50 AM
MarkNYC MarkNYC is offline
Question Air hose from rear air compressor for load leveling
I have an extended 2001 Pontiac Montana with a load-leveling air compressor (that also doubles as air pump for adjusting tire pressure - comes with hose and gauge). There is an air hose that has corroded and come disconnected. The hose is marked with '7/32 GM6148-M 03066 ABG-3'. I haven't been able to tell how much of this hose I need to replace the whole run and if any type of replacement 7/32 " hose will do. Has anyone encountered this repair? Thanks - Mark
Old 06-13-2011, 01:29 PM
rkvons's Avatar
rkvons rkvons is offline
Re: Air hose from rear air compressor for load leveling
I replaced my passenger side one this spring. Bought it from http://www.gmpartsgiant.com/. Paid $31.85 shipped. I don't know about splicing them. It felt really good putting a new one on.
Old 07-11-2011, 11:45 AM
joe49424 joe49424 is offline
I have a 2004 Montana with what I believe is the same issue. There is a section of air tube hanging off a tee connection near the pump. I read on another forum that this should connect to somewhere at the top of the pump which you cannot see from below. I'm going to investigate this later this week. But if anyone else has more info please let me know. Thanks in advance. Joe
Old 07-11-2011, 12:36 PM
rkvons's Avatar
Just be aware that the hard plastic line is the high pressure side and the soft vacuum hose looking line is the air input side.
The Following User Says Thank You to rkvons For This Useful Post:
joe49424 (07-11-2011)
Air Compressor - Auto Load Leveling 1999montana Montana/Montana SV6 1 05-26-2009 11:59 AM
'95 auto level issue.. car doesn't know when it's level Brueggz Roadmaster 1 04-07-2009 04:30 AM
Valve for Montana load leveling system? Not airing up properly upon loading/unloading goony Montana/Montana SV6 3 09-06-2005 01:48 PM
Load leveller compressor/rear access. socket ace395a Montana/Montana SV6 4 03-27-2005 02:21 PM
possible fix for bad load leveling system mschus MPV 1 01-24-2005 03:49 PM
