Old 06-10-2011, 07:00 AM
chubcobear's Avatar
chubcobear chubcobear is offline
How to bypass a/c compressor? 95 Lesabre
I had my a/c compressor fail . Maybe because a/c condenser fan was not coming on and we had very hot days?
How do I bypass the compressor so that I can have heat this winter? I understand that the compressor runs whenever heat/cold controls are on. Is it possible to have heat without a/c compressor running? Thanks.
Old 06-10-2011, 07:50 AM
maxwedge maxwedge is offline
A990 racer
Re: How to bypass a/c compressor? 95 Lesabre
Disconnect the electrical connector, no? No effect on the heater.
The Following 2 Users Say Thank You to maxwedge For This Useful Post:
chubcobear (06-10-2011), mrrbhm (08-03-2011)
Old 06-10-2011, 08:24 AM
chubcobear's Avatar
Thanks Maxwedge. I was laboring under the misconception (I guess) that the compressor ran all the time and the blend controller over the glove box
balanced the temps with heat from the heater core and a/c air.
Old 06-10-2011, 08:32 AM
Scrapper Scrapper is offline
AF Premium User
if you want to bypass air call and see if you can get a belt without air. or have you figured out another way?
The Following User Says Thank You to Scrapper For This Useful Post:
Old 06-10-2011, 09:22 AM
chubcobear's Avatar
No, Scrapper, I will take maxwedge's advice and disconnect the wires at the compressor. That seems like the proper solution until I can afford a new a/c compressor, condenser fan and relay, etc.
Old 06-10-2011, 11:41 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
I hope you have the radiator/condenser fan control problem corrected. The compressor will not engage in the heat mode. It may cycle off/on during defrost mode to help control humidity. You have nothing to worry about.
The Following User Says Thank You to HotZ28 For This Useful Post:
Old 06-10-2011, 02:48 PM
chubcobear's Avatar
I went ahead and disconnected the connector at the clutch just to be sure that I don't squeal and smoke the clutch anymore. HotZ, the heat/A/C controls were working perfectly before the compressor clutch decided to smoke out. I had fixed the controller several months ago by installing a new one behind glove box. Lots of contortionists fun. Thanks to all. I will get a new compressor installed when I can afford it.
Old 06-11-2011, 06:33 PM
AF Premium User
even upuged may go for awile or any time it will lock up so i thing you better get a compressor one as so has you can.
good luck.........
Old 06-11-2011, 09:54 PM
HotZ28's Avatar
AF Moderator Elite
If you install a new compressor, don't forget to replace the orifice tube & accumulator/drier, otherwise the compressor warranty will be null & void! If the orifice tube is found to be clogged, the system should be flushed before the new compressor & other parts are installed. I think Scrapper may be thinking the clutch hub bearing may be seizing, which is possible. If so, and until you get the new parts, you should install an A/C bypass pulley assembly with a shorter belt to eliminate the compressor. BTW, what year is you're LeSabre?
Old 06-12-2011, 11:04 AM
AF Premium User
yes zzzzzzzz if you look back i told him to get a belt without air on belt.
Old 06-13-2011, 05:40 AM
polarzak polarzak is offline
Originally Posted by khung88876 View Post
You can also pull relay, i pull mine during winter, dont need compressor kicking in just for floor&defrost burning more fuel back in for summer" need that AC lol
You may have been lucky. That is a great way to have your compressor seize up from non use.
Old 06-13-2011, 07:27 AM
A990 racer
Lightbulb Re: How to bypass a/c compressor? 95 Lesabre
Originally Posted by polarzak View Post
you may have been lucky. That is a great way to have your compressor seize up from non use.
remember the compressor will not engage below 40 degrees anyway.
Old 06-14-2011, 05:39 AM
Maybe on some vehicles, but I saw it engaged on my 07 GM when it was about 20 degrees. I was filling my windshield washer and noticed the clutch engaged, and thought, what heck is this. It is winter. After a little research I found the compressor runs in defrost mode (mine was on defrost that day) and it runs in defrost for two reasons:
1. To provide dehumidified air to the windshield
2. To avoid compressor seizing during winter months from non use.
Old 06-14-2011, 06:31 PM
big white bufflo big white bufflo is offline
dorman makes a pully that bolt right in the old location of the compressor work great i put one on my 92 3yr ago
Old 06-18-2011, 01:31 PM
Jrs3800 Jrs3800 is offline
This would be a 73" Belt... But there is only one problem... there is a Torque axis mount in the way... The belt will be incredibly close and actually chaff the belt...
If the Pulley bearing is making no noise, I would run it till I got the new compressor..
Bypassing the AC Compressor/ Serpentine Belt jpletsch Aurora 7 07-05-2008 11:31 PM
bypass a/c compressor 97 caravan chjohnson Caravan | Voyager 1 08-21-2005 09:09 PM
bypass A/C compressor bouliancube Beretta 2 03-29-2005 05:24 PM
90 GrandCaravan - bypass a/c compressor? austin.andy Caravan | Voyager 2 03-02-2005 07:54 AM
can i bypass the ac compressor? bpvs Cherokee 3 05-03-2004 10:01 AM
