Old 12-02-2010, 06:43 PM
Barudar Barudar is offline
Noises while turning
First of all.. I know nothing about cars yet, this is my first which I've been only driving for 2 weeks. I'm goin crazy not knowing what's wrong with my car!
96 Ford Taurus makes a pretty loud noise while turning both right and left. The sound seems to get louder the slower I am going (especially while stopped). I would TRY to describe it as.. the sound of your tires on the freeway, but much louder and the harder I turn the louder it gets, a little more on the left side too. The car is FWD and it comes from the front of the car, doesn't seem to be coming more from the left or right.
It started the first day I drove it, I drove for 45 minutes mainly on a freeway, and when I pulled into the place, it started and it wasn't quiet. After that, it would still only make the sound after driving for a while, but now after driving for more than a week it does it right when I start the car.. HELP!!
Old 12-02-2010, 07:06 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Noises while turning
Welcome to the forum, and to driving!
I'm guessing that the noise you're hearing is the power steering pump. Does it have a whining/moaning sound to it? It is probably low on fluid. Unfortunately, if it's low on fluid, it's low for a reason. There's probably a leak somewhere. Any chance you got a warranty with the car? If you're lucky the leak is just a hose. If you're less lucky, it will be a worn out pump. If you're unfortunate, the problem will be the rack and pinion or a combination of more than one of these items.
You should of course also inspect everything to make sure the wheels and suspension are tight. If the noise is more of a single bang or pop, the problem is probably not the steering system but rather a suspension component.
-Rod
Old 12-02-2010, 08:35 PM
I actually had just replaced the water pump before starting to drive. So I'll check the hoses! thank you
And also, I am looking for a job and have no money, so I cant really get it into a shop yet :/ can't afford it
Old 12-02-2010, 10:17 PM
danielsatur danielsatur is offline
Also see Similar threads at the bottom.
I have flushed, and used lucas power steering treatment with no luck.
Old 12-03-2010, 06:27 AM
shorod's Avatar
SHO No Mo
Note that I said Power Steering Pump, not water pump. Would you describe the noise a bit better (moan/groan, rattle, clunk/pop, etc.)?
-Rod
Old 12-05-2010, 06:40 PM
It is definitely more of a groan. And yea.. woops, I replaced the water pump not the power steering pump >.<
I looked in the power steering fluid container and it was orange and foaming at the top of the dipstick. But after driving it goes down past the dipstick.
Wow, strange.. I just re-checked the power steering fluid again after it sitting for a full day and its very low and NOT foamy at all. What the heck?
Old 12-05-2010, 08:57 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
It's very weird, it should not be orange and especially not foaming. Anyway, you should add immediatly fluid to save your pump. Don't overfill and use the appropriate fluid for your car. Which is ATF-type F fluid (a transaxle fluid) if my memory is good, confirm in your owner manual.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Weird noise while turning CSanderson HHR 0 07-20-2010 09:17 PM
Engine noise while turning sdpsc Cavalier 10 10-08-2004 09:38 AM
Clicking Noise While Turning Wheel TILAW Ranger | Courier 5 08-13-2004 05:34 PM
Clicking noise while turning thephig Accord/TSX/Accord Hybrid 1 07-16-2004 03:08 PM
Clunking noise while turning... jasonmturner Integra 5 04-07-2004 09:51 PM
Tags
noise , sounds , turning
