Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 09-30-2007, 10:32 PM
vwjetta96 vwjetta96 is offline
Exclamation Creaking Sound while turning wheels...sounds like old, rusted door
I have a problem with my Stratus 2.0 and any input would be greatly appreciated!
When I drive the car for a while, I start to notice that every time I turn the steering wheel left or right it does creaking sound exactly like an old door that needs to be oiled.
Usually, I need to drive the car for a short while before it starts happening. It does not do it when the car is parked with engine off. However, it does happen if I just sit in traffic idling or driving. It happens even if I don't go over bumps.
Aside from the noise nothing is going on. No stiffness in steering wheel, nothing unusual performance wise.
Now my guess is a ball joint problem but don't know if I am right or not. Please advice what it could be and if I can repair on my driveway instead of an expensive shop. I have absolutely no money and I am trying to figure out if I could drive the car for a little bit longer without getting into an accident by losing my wheels
Thank you very much!
Old 11-17-2007, 07:12 PM
moparman91 moparman91 is offline
Send a message via AIM to moparman91
Re: Creaking Sound while turning wheels...sounds like old, rusted door
i have the same problem but it when i put is in reverse and drive and going over bumps and other things iv looked at the motor mounts but they look ok but if any won else has this problem check the motor mounts ans the stering ball joints
Old 11-17-2007, 08:27 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
ball joint or TRE
possibly struts too but they make more of a dry rubber squeal type of noise
the 90s ford F150 trucks make the dry metal squeal noise alot, very common
dry joints
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 03-09-2008, 09:00 AM
336,000C/K 336,000C/K is offline
Send a message via AIM to 336,000C/K Send a message via MSN to 336,000C/K Send a message via Yahoo to 336,000C/K
Very comm0on problem with the Stratus is the lower ball joints/lower control arms. they are not greasable and make noise like a creaking door when they wear out. Takes about 2 hours per side labor time and the arm/joints can be found for around $150 a side.
Old 04-06-2008, 02:54 PM
dsramprat's Avatar
dsramprat dsramprat is offline
Send a message via MSN to dsramprat Send a message via Yahoo to dsramprat
It is the lower ball joints. I have some info posted in the following thread:
http://www.automotiveforums.com/vbul...d.php?t=892575
Bending wrenches and turning air into the Sound Of Freedom!!!
Old 06-09-2009, 12:59 PM
pcjunkie7 pcjunkie7 is offline
I have the exact same problem with my 98 Stratus. I think it started around 160K and I drove it for another 15k or so. Now it makes a grinding noise when I turn the wheel sharply and some of what I read sounds like that might be wheel bearings.
