Old 06-04-2011, 11:34 PM
bengort bengort is offline
AC High Side Rapid Fluctuations
Hi everyone,
Please forgive me, I'm new. I have a 97 Chevy s10 PU, 6cyl. I replaced my AC compressor today because my old one blew a seal (but didn't seize up). I also replaced the accumulator, and put the correct oil 150 PAG in--4 oz in the compressor, and 2 oz in the accumulator. (The system calls for 8 oz, but I put 6 in to account for oil already in the evaporator and condenser). I pulled a vacuum for 1 hour, then put two 12 oz cans and a little bit of third can in. It was 98 degrees ambient temp. With the truck idling, the low side was reading between 30 to 40 psi and the high side was reading about 225 psi. Everything seemed to be working fine. I cold air in the cab at about 60 degrees.
Here is my problem: The high side gauge was fluctuating rapidly around 225 psi . I tested my gauges on my toyota and there is no fluctuation--so I know it is not my gauges. What could be causing this, and is it safe to run the AC knowing this problem exists? One note: I did not replace the orifice tube because it was difficult to get to. I'm kicking myself for not doing that!
Thanks!
Old 06-05-2011, 08:33 AM
brcidd's Avatar
brcidd brcidd is offline
Re: AC High Side Rapid Fluctuations
Reciprocating compressors will do that sometimes- it's the pulses in resonance- try upping rpm - see if it smooths out--- really not usually an issue.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
AC...Low Side and High Side polarzak Grand AM 8 05-25-2010 04:45 PM
1990 Prelude High Idle and fluctuation JSPEC motor Tim McCreary Prelude 1 02-16-2006 04:14 PM
Power steering, back pressure on high side rvandyk Sable 3 05-30-2005 12:25 AM
97 passat 1.8t 20v high emissions and fluctuating rev counter drakule '97+ 1 01-23-2005 02:44 PM
Tags
air , condition , fluctuation , orifice , psi
