Old 05-31-2011, 04:28 PM
GreggT GreggT is offline
Vapor Lock?
Just filled up my GP with gas, (it was almost empty) now it won't start. Do I have vapor lock, is the fuel filter clogged? Help please! My car is still sitting at the gas station
Old 05-31-2011, 04:35 PM
rickisrad rickisrad is offline
Re: Vapor Lock?
what year and model. check the ignition relay and fuel pump relay in your engine compartment fuse box, make sure they are in tight. Did you continue to top off after it stopped?
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
Old 05-31-2011, 04:38 PM
Re: Vapor Lock?
its a 2000 GT, 3.8L, didn't actually run out of gas but I'm sure i was close, the low fuel light had been on awhile, it didn't stall or anything, just wouldn't start back up after i filled it up with gas
Old 05-31-2011, 04:43 PM
Re: Vapor Lock?
check those relays. one thing you can do is switch one of the like relays to the fuel pump relay to see if it will start. use one of the relays like headlights or something similar that will not interfere with starting the car. did you completely fill up?
Old 05-31-2011, 04:54 PM
Re: Vapor Lock?
yes I filled er up all the way
Old 05-31-2011, 04:57 PM
Re: Vapor Lock?
oh i see what your saying, after the gas popped i put like another 50 cents in
Old 05-31-2011, 05:08 PM
Re: Vapor Lock?
yeah sometimes it will enter the vapor canister and cause problems, I have replaced a few that were full of gas. again check the relays (ignition, fuel pump and injectors). if topping off caused the problem it may start after some evaporation?????
Old 05-31-2011, 06:42 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: Vapor Lock?
Also check fuses at the glove box and at the engine compartment, might just be a coincidence though.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 05-31-2011, 06:58 PM
Re: Vapor Lock?
went back after about 2 hrs and it started right up? Don't get it!
Old 05-31-2011, 07:03 PM
olopezm's Avatar
Re: Vapor Lock?
That would make people think you might have a fuel pump going bad. When they start failing they can work perfect after sitting for some time, then they will get stressed and fail un til you let it cool down again...
If it happens again try and listen to the fuel pump priming when you turn the key before cranking the engine. If you csan't hear any humming sound coming from the fuel tank it is very likely the pump is the problem.
Oscar.
Old 05-31-2011, 07:21 PM
Re: Vapor Lock?
don't top off the tank. I would replace the fuel pump relay just to be safe it is like 15 dollars. I have had the same problem with my 97. as oscar said it may be possible that the fuel pump may have issues, but I would start with the cheap stuff first.
1985 ford f150 vapor lock? jka F Series 5 09-06-2004 03:07 PM
Vapor lock? 96spyderman Continental 8 08-02-2004 07:31 PM
Vapor Lock?????? motorjock205 Mustang Talk 1 07-21-2004 10:09 AM
vapor Lock?? thomba02 Blazer 1 10-22-2003 03:09 PM
E30 Vapor Lock? jdoug 3 Series 0 11-19-2002 05:30 PM
