Old 08-19-2004, 05:46 PM
jka jka is offline
1985 ford f150 vapor lock?
How would I locate vapor lock in my truck?
Old 08-29-2004, 03:57 AM
ervinj ervinj is offline
fuel or coolant?
ervinj
Old 08-30-2004, 06:41 PM
jka jka is offline
Re: 1985 ford f150 vapor lock?
I'm thinking fuel.My truck won't start after I drive it. I have to wait 15-30 minutes after I go somewhere before it will start again. It will turn turnover but it won't catch then I wait the time and it will start.
Old 08-31-2004, 05:18 PM
GreenlandMopar GreenlandMopar is offline
i had the same problem and it turned out to be the ICM ignition control modual (gray box on the side of the distributor) if you have it tested it will test good because they only mess up when they are warm...
Old 09-03-2004, 09:47 PM
Paul Masley Paul Masley is offline
You also might want to check the coil.
Everybody is an idiot (including me) some of the time, but there are others that make a full time job out of it!!!!!
Old 09-06-2004, 03:07 PM
ModMech's Avatar
ModMech ModMech is offline
Cabed or injected?
If injected, replace the fuel pump (after you have identified that as THE problem using a fuel pressure gauge).
