Old 05-31-2011, 11:16 AM
Vladamor's Avatar
Vladamor Vladamor is offline
Send a message via MSN to Vladamor
Ferrari F40 LM & F40 Competizione
Hi.
I was just watching and listening to some videos of the F40LM at Youtube, and now I'm wondering... why not to build one??
Then I searched in HLJ for one, and found these.
F40 LM:
http://www.hlj.com/product/FUJ12308
F40 Competizione:
http://www.hlj.com/product/FUJ12387
The fact is both looks the same. So, can anyone tells me the differences between those two?? From what I can see, are exactly the same.
I hope you can help.
THANKS & Cheers
Old 05-31-2011, 12:57 PM
ZoomZoomMX-5's Avatar
Re: Ferrari F40 LM & F40 Competizione
Read the headers very carefully. The more expensive kit has photoetch included. Otherwise same kit.
My Fotki Album
Old 05-31-2011, 01:32 PM
Vladamor's Avatar
Yes I know. I'm not asking about the box content, if one is better or not. I mean, is one more racing focus than the other or something like this? Those real cars are the same then?
Old 05-31-2011, 07:05 PM
Helico's Avatar
Helico Helico is offline
These two kits are identical except the second link shows a newer package. Both of them have the same PE set (quite limited in terms of detail).
Here is an even older package but with the same stuff otherwise (including PE): http://cgi.ebay.com/Fujimi-1-24-Ferr...#ht_1527wt_905
I think it is more appropriate to call this kit "LM" rather than "competizione". A competizione version is more like this: http://cgi.ebay.com/Tamiya-1-24-2428...#ht_3388wt_905
These two versions differ in several areas (at least with respect to what's in the box): spoiler, width/fender, front lamp, front and rear bumpers, rims and a couple this and that. Fujimi kit is a curbside by the way.
The Following User Says Thank You to Helico For This Useful Post:
Vladamor (06-01-2011)
Old 05-31-2011, 11:19 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Fujimi's latest F40LM kit (now re-labeled as F40 Competizione) has a different PE set most likely made by KA Models, and the difference is apparent for it has an additional instruction with photos.
Off the top of my head, the LM was meant to be a race car, but only a few actually raced, and the rest went to collectors. The actual racing F40s are production based ones (with some racing parts originally developed for the LM) that competed in Italian GT championship (like the Tamiya's Monte Shell kit) and JGTC (like Fujimi's Taisan Starcard F40). Then there are fully race-prepped F40GT and GT Evoluzione that raced in BPR, Le Mans etc., and those are kitted by MFH and S27.
Hiroaki Fukuda
The Following User Says Thank You to hirofkd For This Useful Post:
Old 06-01-2011, 02:58 AM
Vladamor's Avatar
THANK YOU!!
Those kind of things were what I wanted to know. So, the kits are mostly the same, but the real cars not. The Tamiya Monte Shell is out of production, that's why I look Fujimi's....
HELICO, thanks for your info too!!! So, since the Tamiya is Out of Production, the best choice will be the Competizione.
Thank you very much.
CHEERS
Old 06-01-2011, 06:07 AM
tifosi16's Avatar
tifosi16 tifosi16 is offline
The Fujimi kit is the standard roadgoing version with just a new body that is 80% correct for a LM version. To build an accurate LM you need to modify a LOT of parts, engine, interior, seats, exhausts etc etc. The bonnet scoop is too shallow, you see where I am going...
Only 19 LM's were ever prepared by Michelotto, which were all sold to privateers.
A couple of GTE's were built which was a further evolution and raced at LeMans etc as said above. Also build by Michelotto for Ferrari.
Technically the 'competizione' never existed. Cars like the Tamiya Shell one, were standard road going F40's that were privately modified.
I am currently doing a LM that (hopefully) will be accurate, look out for the WIP I'll have up soon...
Ciao!
Old 06-01-2011, 11:00 AM
Vladamor's Avatar
Ciao!
Hi friend!
Yeah, normally with a Fujimi model you need to correct a lot of things. Since I don't have the kit already I can't compare...
I've found a site where they sell the Monte Shell yet. May I suppouse to think that the Tamiya Monte Shell is better than the other two??
Oh, I'll look forward to see your LM soon.
Thanks for your answer anyway. I'll keep looking.
CHEERS
Old 06-01-2011, 12:13 PM
speedphreak speedphreak is offline
I have this model to make. The window section behind the B pillar is a pain in the butt. There is a huge gap if you look inside with the windows in place. How can I correct this?
Old 06-01-2011, 02:29 PM
tifosi16's Avatar
Funny for you to mention this, as I was fiddling around with it last night, figuring it out.
The easiest way is to glue a triangular piece of plastic card into the body, where the gap will be once the windows are in, and paint it black, as this bit on the real car forms part of the blacked out section above the rear 3/4 window. Once painted it should be invisible.
Give me another night or 2 or 7 to fine tune it, and I'll post a pic for you once I've got it...
Food for thought in the mean time...
Old 06-01-2011, 05:56 PM
pb4007's Avatar
pb4007 pb4007 is offline
Hello Vladamor, check out here. They have pretty cheap F40's. Not sure if they have the one you're looking for, but I hope this helps.
Old 06-01-2011, 06:42 PM
Helico's Avatar
Ouch, my bad. I wasn't looking hard enough (sloppy). That sure looks like a better PE set than the old one.
Old 06-02-2011, 07:53 PM
Thank you very much!!! This has kept me from painting the car. I really appreciate it!
Old 06-03-2011, 03:40 AM
till.a.fischer till.a.fischer is offline
I have the Monte Shell car on the shelf and would like to pint out one thing:
The Monte Shell car has a standard roadgoing body, prepared for racing - just like the original car.
The Fujimi kits have a totally different body - more like the Michelotto-built F40LM or GTE: wider body, different rear wing....
Old 06-03-2011, 07:30 AM
Vladamor's Avatar
Yeah that's something I've noticed, and I didn't knew it. I suppouse I'll buy the Monte Shell version and the Fujimi Competizione... It will be great to join both and make a super model, ha ha ha... Nah, just dreaming...
CHEERS
Tamiya 1/24 F40 competizione monte shell JWGZ WIP - Motorsports 8 06-13-2011 11:14 AM
Ferrari F40 "Featured" Britain's Biggest Crime Syndicate Case carrolltrust General Discussion 0 07-28-2010 09:14 AM
Tamiya Ferrari F40 & Skyline R33 pettercardoso WIP - Street 18 02-10-2004 05:10 PM
Kyosho's new Ferrari 365 GTB/4 Competizione eweston17 Diecast Car Modeling 6 02-15-2003 05:56 PM
