Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 05-31-2011, 07:42 AM
allen405 allen405 is offline
'95 trans sport alt issue
it has the 3.1 v6. The problem is that it keeps wrecking alternators. It's a serpentine belt system and the alt is hard mounted so there is no adjustment, but after a couple of months the alt gets noisey like the bearings are going out. Has anyone had this issue before?
Old 06-03-2011, 05:26 AM
LMP's Avatar
LMP LMP is offline
Re: '95 trans sport alt issue
THe belt tension in maintained by a tensioner pulley, the spring or the tensioner applying the needed pressure. Is there any possibility that the original belt was replaced qith a shorter one, cranking the tensioner more than it should be? I think the 3.1 must use an additional idler if the a/c compressor is discarded: a change in belt routing due to a different idler diameter may force to an improper change of belt length.
Other than these possible factors, I do not see why it would start to ruin the alt bearing.
ALso, long time ago, while still under garantee, I had a noise condition on mine where they had changed the alternator ....to no avail as it was finally the a/c compressor free wheel bearing .
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
trans sport keyless entry joelbear70 Trans Sport 2 12-16-2009 10:15 PM
97 Pontiac Trans Sport Oil Pressure light mspontiac Trans Sport 2 07-07-2009 05:52 PM
97 Trans Sport. Electrical Issues wolfawk295 Trans Sport 1 08-02-2007 01:57 AM
Pulling to left when shifting - '95 Trans Sport cb50chevy Trans Sport 1 04-20-2007 09:44 PM
Cruise Control Cable Broke - '95 Trans Sport cb50chevy Trans Sport 4 10-27-2006 06:36 AM
