Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 12-09-2009, 12:17 PM
joelbear70 joelbear70 is offline
Question trans sport keyless entry
hello i have a 1995 pontiac trans sport i love the van except 2 issues i cant find the programming instructions for the keyless entry and the overhead temp shows minus 40 everytime i start the van the highest it has read is minus 18 how can i take care of these 2 problems any help would be greatly appreciated thanks
Old 12-12-2009, 05:39 PM
Jrs3800 Jrs3800 is offline
Re: trans sport keyless entry
To program the keyless entry, you will need to remove the glove box... Look above the area of the light, and you will see a black box this will be the keyless entry module... On this module you should find a button, you will press and hold that button to program the remotes..
I think if needed I can dig up the instructions to program the system...
For the temp reading you may have a bad Temp sensor... It resides ahead of the radiator attached to the header panel...
Old 12-16-2009, 10:15 PM
jarl jarl is offline
To expand a little bit what JRS said:
- Ignition "on"
- press the button until the power locks cycle once. Release button
[From this point on, repeat for each remote]
- press and release the button once again
- you have 10 seconds to press any button on the 1st remote you want to program
- once you press the button, the module will indicate the remote was accepted by cycling the locks again.
'94 Trans Sport 3800
Tags
1995 , pontiac , sport , trans
