Old 05-30-2011, 11:00 AM
ZiggyPA ZiggyPA is offline
Question can r12 be replaced by r409a?
I have a 91 Buick Park Avenue and want to recharge the A/C. It is becoming very hard to get R12 overhere, one shop recommends the r409a refrigerant.
Is this a good substitute?
Old 05-30-2011, 11:10 AM
danielsatur danielsatur is offline
Re: can r12 be replaced by r409a?
Buy convershion fittings for 134A at any local Autoparts store, and buy 134a from Big lots for $8.00 a can.
Old 05-30-2011, 12:01 PM
I found a shop who offers 2 other substitutes for R12: R413 and R437a.
R437a is a new refrigerant. Is it better as a substitute than 413 and 409?
Old 05-31-2011, 12:49 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
I'm not familiar with what is the common refrigerant used in new vehicles over there. In the U.S., R-134a is what is used. It is a pure gas, tetrafluoroethane. Because it is pure, it is currently recyclable by professional shops and because it does not harm the ozone (so they say), can be handled by the average guy as well. However, shops use equipment that can remove and store it on site, to keep it from entering the atmosphere.
All of the refrigerants you mention, R-409, R-413, R-437, etc., are actually blends of different pure gases to try to mimic the performance of an old refrigerant without causing as much damage to the ozone should it be released. Using one of those would require someone experienced in handling that refrigerant in particular.
As mentioned, there are many R-134a retrofit kits available in the U.S., but please let us know what is used over there.
My recommendation would be to convert over to what is used in new vehicles over there, which should be the R-134a. The big reason being is that should your car's A/C ever need service, the refrigerant can be recovered without requiring the shop to dispose of it as a hazardous substance, which can be costly. Using the -409, -413, or -437, you would be beholden to that shop to do all your future work.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 05-31-2011, 06:39 AM
R134a is the standard refrigerant over here as well. Converting is too costly and time consuming.
I've found a shop where recharging is not expensive. R409a doesn't seem to be suited for automotive a/c's. R437a seems to be the best alternative for R12.
Old 05-31-2011, 10:09 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Do what you want, but how is R134 more expensive??? The fittings are $6 and the refrigerant will cost you about $20.
You are probably getting quotes for a whole system conversion which is the "right" way to do it, but if you flush the system and recharge with PAG oil and r134 it will cool the car. Expect average vent temps to rise about 2-4 degrees, but you can expect that with any "incorrect" refrigerant.
I've done several r134 cheapo conversions and they work fine.
Dragging people kicking and screaming into the enlightenment.
Can you replace the 3.2 w a 3.5 from a 300m?? Intrepid es 3.2 Intrepid 6 12-23-2009 12:25 AM
r12 replacement towerguy Ranger | Courier 5 08-22-2005 03:37 PM
Hazard button broke. Can you replace just the button? XtremeXP Jimmy 2 02-09-2004 06:53 PM
Hi, I have a 99' 3.5 with rod knock 29k can you replace rod bearings in car? jimg300 Intrigue 1 11-11-2003 10:28 PM
how can i replace the light bulbs behind the air conditioner console? IntegraTypeRS Integra 2 04-27-2002 05:12 AM
