Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 04-30-2005, 07:23 PM
towerguy towerguy is offline
Question r12 replacement
1993 Ranger. Now that warm weather has finally returned to this area, I used A/C for the first time. Compressor cycles on and off, and a guy I work with thinks I need to recharge the A/C. My truck uses R12, which is now ridiculously expensive. Does anyone know anything about replacement refridgerants? Anything compatible with R12? I want comfort, but I can't justify spending too much on this. Any suggestions appreciated. Thanks, TG
Old 05-01-2005, 01:05 AM
bd2988 bd2988 is offline
Well, hopefully I can be of some help. I also have a 93 ranger, and was looking for the r12 refridgerant. I've found some r12 recharge kits and replacement kits, that come with everything you need to recharge your r12 system. Less than 50 bucks. Yeah, for less than 50 bucks... heres a link:
http://cgi.ebay.com/ebaymotors/ws/eB...970434088&rd=1
Hopefully you have an eBay account. If not, I HIGHlY recommend it. Ebay has saved me TONS of money, and has helped me find things that are now obsolete. Anyways, hope this works for you.
Old 05-08-2005, 03:14 PM
Fir Las Fir Las is offline
Towerguy,
Instead of recharging with R12 freon, which is now terribly expensive, why not buy a conversion kit for 134a? For less than $50 you can buy what is necessary to convert your system and cans of $134a are cheap by comparison: about $3-4 per 12 oz can.
Then, should your system develope a leak later, you can recharge with 134a for very little money.
matis
Old 05-12-2005, 09:19 AM
2000mudder's Avatar
2000mudder 2000mudder is offline
Re: r12 replacement
yes you guys should just buy the conversion kit. all it is is a couple of screw on fittings wich might seal your leaks you have. you do have a leak if you have to add freon!!!!
Old 06-16-2005, 08:29 AM
reborn55 reborn55 is offline
Send a message via AIM to reborn55
I have a nearly full system--is there any product out there such as Hot Shot that is fully compatible with R-12 that can be added to existing system without evacuating and recharging. Thanks
Old 08-22-2005, 02:37 PM
kuto kuto is offline
yes there is,get the freeze-12 , its the direct replacement for r12 and is alot cheper and better than 134
