Old 05-29-2011, 05:16 PM
moliva1568 moliva1568 is offline
Headlight issue
I have a 98 Cavalier and have been experiencing headlight issues. The headlights don't come on when turned on and the only lights working are the daytime running lamps. The high beams work but they don't stay on unless i hold the lever back. Any suggestions? I took out the bulbs and they don't appear to be blown yet. I believe the daytime running lights run of the same bulbs as the lowbeam. Why would one work and not the other?
Old 06-11-2011, 10:56 AM
Mike2009 Mike2009 is offline
Re: Headlight issue
In my experience this is due to a bad ground. I would start by making sure that there is 12v at the lights on one side because they are ground switched. If there is then it's most likely the nasty little ground splice under the battery. This tends to go bad from water and windshield washer fluid dropping on it.
To fix mine I ran a new ground between both lights and then back to the switch in the dash. The original wire was too far gone to save. This has worked well. This was also the fix on another j body for the headlights and the daytime run lights not working. It was just another ground.
As far as the lamps go the bcm lowers the voltage to the high beams and used the high beam lamp for drl. The drl and low beam share a ground back to the switch.
Hope this helps.
200 headlight issues farmallboy91 Cavalier Problem Diagnosis 3 07-12-2010 09:08 PM
92 Corolla DX Headlight Issues chrisg000 Corolla/Matrix/Voltz 2 12-28-2004 09:57 PM
97 blazer headlight issue tspencer73 Blazer 3 10-06-2004 02:14 AM
Major Major Headlight Issues. Your A Geneious If U Know... Djs87 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 16 06-14-2004 09:40 PM
93 Ford Escort Headlight issues! HPDOFNTX Escort 3 05-19-2004 02:11 PM
