| Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines. |
Rear rotor removal
Car: 2002 Maxima
My rear brake rotor is very hard to remove. Are there other parts I need remove? I removed pads and caliper. Any suggestion? Also need to know torque for the lug nuts. |
Re: Rear rotor removal
Check out the autozone.com repair manual, it may help on the removal. I have never sone a brake job on your vehicle but according to the maual you may need to remove nut to remove rotor.
I hit the rotor (actually hub) with a steel hammer until it gets loose. It worked.
Next question is how to push the brake plunger back. It was really really hard to push. I was able to rotate it a couple of times, but it never get back. |
Do remember to lube the piston (under rubber boot) ! ONLY with special BRAKE ! grease; boosts brake performance over 10% Later, do remember TO USE brakes. I mean while parked once a month real hard push so that you exercise all cylinders and the lube ... you have now added on each piston ... and swap the fluid again after 2 yrs. Dont use brakes = rust em again... See here http://www.cardomain.com/ride/748507...maxima/page-18
. Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507 ![]() There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14 |
Thanks for your help.
I made a tool to rotate the piston using long-nose plier. The noses of the plier were open as much as diagonal distance of two notches, then tied the handles with a stell wire. Now the plier is like an "X" with handle connected so that I did not worry about keeping right distance of the noses. For one side, this was enough to rotake the piston with one hand and the other hand holding the piston body. The other piston was really hard to turn. So I installed the torque member and caliper without pads. Since the piston is held firmly on the calliper, I was able to rotate the piston with both hand. "Let the right tool do it." Yes, the X-plier is semi-right tool in this case. One thing I forgot is that one notch on the piston head should be align with the pin on the back of the inner pad. Regarding torque: 17 mm holding torque member: 28-38 lb-ft 14 mm holding caliper: 16-23 lb-ft Lug nuts: 80 lb-ft while the tire is airbourne. Another question: The old shims did not fit on new pads and new pads had shim like plate on the back. Should I worry about putting shims? |
However, the grease makes all the difference: it also works in sealing, moisture has harder time to pass into the fluid. In the end, swap the fluid.
