Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 05-26-2011, 08:47 PM
b2600i b2600i is offline
82 P30 constant power to starter
hello,
1982 Chevy P30 Chassis, Forward Control, 5.7 V8 4BBL.
New starter, new igniton switch. There is no Neutral Safety Switch (transmission mounted) I jump two wires to allow it to start.
When i turn the key to start, the starter engages. when the key springs back, the starter still engages. The engine turns over but will not start (diff prob.) The starter just keeps cranking.
I dont know much about the electrical side of vehicles. How do I troubleshoot this problem? I assume the ignition wire to the starter solenoid is sending 12V but it is still hot when the key is sprung back to the run position. What would cause that? Is there some type of electrical component malfunctioning or as simple as a faulty wire? Any help would be appreciated.
Old 05-27-2011, 05:18 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 82 P30 constant power to starter
Originally Posted by b2600i View Post
hello,
Better fix that neutral saftey switch before someone starts in in gear and runs over something or somebody.
How or when did the problem start?
If after a starter replace than that is problem.
If two small wires to starter solenoid make sure they are not crossed.
Remove the purple start wire to solenoid and check for 12 volts on it key in run position.
It should only have 12 volts key in start position.
MT
Stereo problem- fuseOK, wiringCorrect...No constant Power rtodde '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 09-18-2008 06:20 PM
No Constant power in new stereo chelseyr Grand Prix 1 09-18-2007 02:24 PM
constant power twonski 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 4 04-28-2007 12:36 PM
amp getting constant power yako1977187 Interior | Audio | Security 4 04-15-2006 10:15 PM
Radiator has constant power davvpar Rabbit 2 05-22-2005 02:59 PM
