Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 03-19-2006, 08:14 PM
yako1977187 yako1977187 is offline
amp getting constant power
I hooked up amp & sub it seems to be working ok (at low volume)problem is my amp is getting constant power to it.The remote wire is run from accessory fuse(only gets power when radio is on)The power wire is run straight from the battery(in line fuse)The ground wire is mounted in the trunk.any suggestions thanks.(06 civic si)
Old 03-19-2006, 09:12 PM
InstallTech's Avatar
InstallTech InstallTech is offline
Re: amp getting constant power
Check your turn on lead while the system is off and the lead is still connected to the amp. See if you still have power. Disconnect the turn on lead and test the input on the amp where the turn on lead would go. If you *still* have power to that input after the lead has been disconnected, then you have a problem with your amp's circuit board.
I reject your reality, and substitute it with my own.
Old 03-19-2006, 11:27 PM
thanks install tech, my amp is functioning fine I'm wondering if bad ground connection may cause this problem or remote lead is in nonsuitable fuse slot(15A) any ideas?
Old 04-15-2006, 09:43 PM
Audiobahn77 Audiobahn77 is offline
try a different ignition source
Old 04-15-2006, 10:15 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
sounds like your auto turn-on wire is connected to a constant 12V source
