Old 05-25-2011, 08:45 PM
bullard bullard is offline
88 silverado 1500 electricle problem
My power windows and door locks do not work on me 88 silverads 1500 Help
Old 05-25-2011, 10:24 PM
fiserman fiserman is offline
Re: 88 silverado 1500 electricle problem
My dads went out on his 88 a few years ago. He had between 90 and 100,000 miles and all it was was I had to change the drivers and the passanger side swiches. Cost 25.00 for each one at the dealer. I would at least make sure I had power to the switches first. If you don't may have a fuse blown. Good Look.
Fiserman
Old 05-26-2011, 01:00 PM
Thanks, fiserman. None of them work on either door. Door locks don't work. Would it be the same fuse?
Old 05-26-2011, 05:19 PM
I think it may be the same fuse but not sure. Been a long time since I changed his. Check your owners manual if you have it, it will help. But I can tell you when his went out I had to change All switches, all window switches and all door lock swiches they couroded or something and I checked all switches and they all were bad. All your switches may not be bad. I paid about 25.00 dollars a switch so I wouldn't recomend doing that unless your sure they all bad. Thats why I would make sure your getting power to them first. I can tell you if the drivers side switch is bad it can keep the passenger side from working but it should not effect the door locks.Good Luck
Fiserman
Old 05-26-2011, 07:12 PM
j cAT j cAT is offline
with a meter check all fuses..then check for power/12 volts at all fuses engine running.....then check driver door for power at the door window/lock switch....
key off windows usually will not work, but door locks will..this would mean 2 fuses..
door wiring,connector in door,ignition switch, fuseable links..etc...etc.....
with not having a voltmeter you will have a very hard time finding this ..
Old 05-27-2011, 05:16 PM
777stickman 777stickman is offline
My '88 wiring diagram shows two 30 amp circuit breakers (not fuses) on the right side of the fuse panel. One is ACC/IGN for the windows and the other is ACC/BATT for the door locks. Both circuits share the same ground source.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
2000 Silverado 1500, Heat Problems doctorhrdware Silverado 5 12-28-2010 05:40 PM
2000 Silverado 5.3L 1500 4x4 Silverado_Dude Silverado 21 11-24-2009 10:02 PM
95 Ram 1500 Heater problems ocpaul Ram Pickup | Ram SRT10 3 11-13-2009 04:24 PM
2001 Silverado 1500 Tranny Problems shordmcman Silverado 6 11-05-2009 09:27 PM
01 Silverado Tranfer Problems kash1235 Silverado 0 04-14-2009 05:44 PM
