Old 05-24-2011, 10:37 AM
sgf59 sgf59 is offline
High Pitched Whistle sound like it is from HVAC
I have a 2001 Astro that has a high pitched whistle that comes and goes when the Air Cond is on or off. It sounds like a Vacuum leak. Everything seems to work ok it is just anoying. Has anyone else had this problem and found out exactly what is happening? Thanks.
Old 09-28-2011, 09:59 AM
Roaster Roaster is offline
Re: High Pitched Whistle sound like it is from HVAC
I have a 1999 with the same problem. I also just go a Engine code P0542 Fuel tank pressure low voltage. I just changed the Fuel pump and then the AC compressor. Everything works fine but that code needs to be fixed. I know that they don't make this stuff to last but for what they charge it should last at least 30 years. Any help would be appreciated. And if I find out anything I will post it.
Thanks
High Pitched Whistling Sound in 98 Ford Explorer Sport promark32 Explorer | Explorer Sport Trac 8 04-16-2007 07:06 PM
02 Explorer High Pitched Whistle Sound michigan Explorer | Explorer Sport Trac 6 07-19-2004 03:16 AM
Sports trac high pitch whistling sound?! mtack Explorer | Explorer Sport Trac 1 01-31-2004 10:14 PM
High pitched whistling under hood Spectre927 Integra 14 10-04-2003 01:24 AM
High pitched whistling tartan Integra 10 04-20-2002 02:14 AM
