Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 05-13-2011, 11:24 AM
82Stang 82Stang is offline
Overheating
1998 Dodge Ram 1500 318/5.2L 213K
Truck ran normal before, just using coolant, slight white out tail pipe. Noticed pinhole leak at back of timing cover gasket and radiator was shot. Parts replaced.... Radiator, thermostat, radiator cap, water pump gasket and timing cover gasket. Water pump looked good and tight, fins excellent.
Propped up right front to bleed, just kept getting big bangs of air coming out of radiator open cap every 2-3 secs. So much so, it blew a cup or more of coolant out with it. Got hot. Let it cool down, then topped off radiator and ran. Could hear noises from heater core, possible leakage. I bypassed the heater core under the hood by hooking the hoses together. Topped system off once again and ran. With radiator cap off, let it run for half hour and I don't get that big burp or even opening of the thermostat. I am positive the thermostat is not opening because the radiator is stone cold and the closer I get down the top/bottom radiator hoses to the water pump/intake, they get hot. I've bled the heck out of it and when I install the radiator cap, the temp rises steadily to overheat. Oil looks good, no milkshake, trucks sound like it runs fine.
Why wouldn't the thermostat be opening? I could purge air forever it seems and it still get's temp gauge pegged. Thanks for your ideas.
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
Old 05-13-2011, 07:45 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Overheating
I drill a 1/16" hole in my thermostats to relieve air and let the hot water get the the thermostat.
The thermostat in my Cummins comes with 2 small holes for that reason.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 05-14-2011, 07:22 PM
Re: Overheating
These Dodges aren't a pleasure to burp. Air in the system is a common problem. One of which I have been working on for some time. If that is the only problem, I will be happy.
Rodney Dangerfield
Old 05-15-2011, 11:28 AM
aleekat aleekat is offline
Re: Overheating
Run it without the thermostadt. If it doesn't overheat. New thermostadt bad
Old 05-15-2011, 06:49 PM
Re: Overheating
I'm going to be safe and sure, by boiling the old one and see if it opens, same with new one. I'm pretty sure it's an air pocket issue though. Everything I've read says to lift the right front of the truck, which I did and tried bleeding it many times, but thermo wouldn't open. One told me to have truck level, otherwise air will get trapped. I would not be surprised at all to find out the new thermo was bad though. The quality of new parts today isn't what it used to be. Was also tipped about filling the engine through the thermo hole when open, thus making bleeding easier. Thanks for the response.
Rodney Dangerfield
Old 05-16-2011, 02:02 PM
Re: Overheating
Problem solved. An obstruction in the lower radiator hose. Never would've found it unless I replaced the thermostat. Thanks for your responses and ideas.
Rodney Dangerfield
Old 05-16-2011, 06:15 PM
AF - Advisor
Re: Overheating
Thanks for the update.
What sort of obstruction...bird nest?
Old 05-16-2011, 06:21 PM
Re: Overheating
Piece of rubber/plastic wedged in.
Rodney Dangerfield
Overheating...overheating...overheating... 92 Firebird Camaro Discussions 13 09-08-2006 11:16 AM
'92 dynasty...overheating...OVERHEATING yooperfly General Discussion 8 07-24-2005 10:04 PM
overheating, not overheating racandbb Caravan | Voyager 0 06-23-2004 07:59 PM
89 Cherokee overheating...and overheating... frakkis Cherokee 6 05-01-2004 11:54 PM
truck overheating but gauges do not indicate overheating wucus Explorer | Explorer Sport Trac 1 10-24-2003 04:04 PM
