Old 05-11-2011, 05:25 AM
cruiser69 cruiser69 is offline
Car Will Not Start
I have an 02 GT 3.8 with about 88k on it. I drove it yesterday with no problems at all. Went out his morning and it will crank over but will not start. What should I look start testing to find the problem?
Old 05-11-2011, 08:53 AM
Re: Car Will Not Start
I checked the fuel pressure and it was fine and spark was ok also. Then I tried to start it again and it fired right up. Does anybody have any idea what happened. I do not feel like getting stranded somewhere. Thanks.
Old 05-11-2011, 06:05 PM
rickisrad rickisrad is offline
there is an ignition relay and also a fuel pump relay in the engine compartment fuse box, make sure those are in there tight. I have had several times I had to push those in on my and a customers car.
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
Old 05-11-2011, 08:07 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
They might be either sticking or going bad; In case they are tight I would replace them just to be on the safe side, these are not expensive and can be found at most auto parts stores.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 05-11-2011, 08:48 PM
FishFind FishFind is offline
One Hot Shot
any security light on>?
Old 05-14-2011, 08:12 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Not much can be done for diagnoses when it starts and runs fine. Next time it wont start you need to check if your missing fuel or spark.
Any stored Diagnostic Trouble Codes?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
done with oil pan now car will not start jumped it and started smoking? nickfromboston Town Car 2 03-31-2009 07:24 AM
Security light comes on and car will not start vballplayer Alero 1 11-06-2003 04:41 PM
Car will not start Robinson 3 Series 1 10-17-2003 02:57 PM
car will not start salinas 3 Series 1 08-05-2003 04:49 AM
