Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 05-11-2011, 12:38 AM
pauly713 pauly713 is offline
03 crown vic interceptor
I just bought a 03 crown vic interceptor and problems started after i left the gate. It started with the original battery dying so i bought a new one. 2 days later the car wouldnt start due to a drained battery again. I got the car jump started and noticed the rear defrost was on and wont turn off. So i took the rear defrost fuse out because summer is almost here. After that it was fine. Then i took the tail lights off to nite shade them and when i was done with them i rehooked the lights a tightened them down So i turned the lights on to see my work and found out that the rear lights come on but dont flash. I checked the fuse and it was blown so i put in another fuse and it blew too, then i got frustrated and got in the car to drive home but i couldnt put it into gear. Can anybody please help!
Old 05-11-2011, 07:24 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 03 crown vic interceptor
Look aty the stoplight switch on the brake pedal. These are known to crack the connector housing and can short the power wire to ground and blow the fuse. You should be able to turn the key 1 notch ( juu8st before dash lights come on) and then shift into neutral to start it and you can drive it someplace to work on it with a friend following you.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
The Following User Says Thank You to way2old For This Useful Post:
pauly713 (05-13-2011)
Old 05-13-2011, 01:20 AM
I found the problem after i finished nite shadeing the tail lights and reinstalled them a wire had gotten sliced and came into contact with the car and fried some fuses. A trip to the auto parts store for some new fuses fixed the problem. Thanks for the reply.
Crown Vic 5 speed swap, help jnslick Crown Victoria 2 07-10-2010 09:34 PM
1998 Crown Vic Hesitats after wash fatcat0915 Crown Victoria 5 11-11-2009 03:58 PM
2001 Crown Vic Interceptor - Fueling Problem mrorange6 Crown Victoria 3 07-07-2009 07:20 PM
04 PI Crown Vic Zeepian Crown Victoria 0 03-29-2009 01:54 PM
1988 Crown Vic Interceptor toxicity61284 Crown Victoria 3 04-22-2005 01:27 PM
