Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 06-30-2009, 06:26 AM
mrorange6 mrorange6 is offline
2001 Crown Vic Interceptor - Fueling Problem
Trying to add fuel is a very slow process, if I hold the handle in all the way the pump kicks off after only a few seconds. I can only add fuel by lightly squeezing the handle and going very slowly. I have tried every conceivable nozzle position..they all act the same. This happens no matter what the fuel level is in the tank, near empty, half, 3/4, same result. I am at my wits end because just filling the tank feels like an all day affair. I'm not getting any codes about a loose gas cap and I don't know what else to check. Fuel filter? If so, where is it?
Any help is appreciated and automatically moves you to the top of my Christmas list..
Old 07-05-2009, 05:56 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 2001 Crown Vic Interceptor - Fueling Problem
Somewhere in the system you have a vent blocked. I don't know if it is the vent tube or the vent solenoid on the top of the tank.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 07-07-2009, 06:42 AM
Thanks for the info...are these easy to access and check? If so, can you advise where they are located?
Old 07-07-2009, 07:20 PM
way2old's Avatar
TOKEN HILLBILLY
The vent tube is the little tube that is attached to the larger filler neck. The vent solenoid is on the top of the gas tank and you will need to drop the tank to check it.
