Old 05-10-2011, 02:38 AM
ericcfx1984 ericcfx1984 is offline
2000 Alero feels bumpy and steering is really touchy
any ideas?
Old 05-21-2011, 10:38 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2000 Alero feels bumpy and steering is really touchy
How many miles do you have on it? Do you still have the original struts and upper strut mounts?
Timeslip 08/12/06
AF Community Guidelines
Old 05-21-2011, 11:14 AM
195,000
no clue how old the shocks/struts are
Old 05-21-2011, 11:20 AM
BNaylor's Avatar
If the struts are original its probably time to replace them with your mileage. As they wear out you feel very bump in the road. Also, worn out front end upper strut mounts which also has a load bearing can cause erratic steering.
Timeslip 08/12/06
Old 05-21-2011, 12:11 PM
that is what I needed to hear
do grand am shocks/struts fit?
Old 05-22-2011, 09:35 AM
BNaylor's Avatar
Yes. Same. Also, aftermarket Monroe, Gabriel or KYB brand struts all fit either the GA or Alero.
If you have an Alero GL2 model it has the same GM performance struts as the Grand Am GT so that should be considered if you want to keep the original ride and handling. For other Alero models it should not be an issue on fitment or use.
Timeslip 08/12/06
2000 Alero 2.4-skips, jerks, dies, poor gas mileage summersdad Alero 8 03-08-2012 09:23 PM
2000 Alero stalls at highway speed skeeter123 Alero 12 04-05-2011 10:48 PM
2000 Alero V6 will not start. Please help. slavetothought Alero 1 10-28-2010 08:45 AM
2000 Alero 3.4 ABS light on, code c1265 skeeter123 Alero 8 01-26-2010 07:51 AM
2000 Alero shut off and won't start darnsuprat Alero 2 02-25-2008 09:24 PM
