Old 05-07-2011, 03:28 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Headlight Issue
Friend owns a 1980 camero Z28, It was parked all winter. Recently he dropped it off at the shop to have a new trans installed. When it came home, the headlights don't work. They worked when it was parked before the snow fell. Are there any wires to look for, maybe a ground the shop could have unhooked without realizing it?
Anyone have a wiring diagram?
Thanks!
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 05-07-2011, 06:29 PM
j cAT j cAT is offline
Re: Headlight Issue
Thanks!
first using a meter see where it is loosing the supply/ground ...could be the current limiter ..fuses need checking..
Old 05-07-2011, 07:57 PM
tblake's Avatar
In God We Trust
Re: Headlight Issue
We got it, one bulb was burned out on the low beam, and the other had a missing ground wire. All fixed.
Now if someone can tell me what the base timing should be set at on this car. 1980 z28 350. Next step is a tune up.
Thanks.
Old 05-08-2011, 08:07 AM
Re: Headlight Issue
Thanks.
timing should be 6 deg BTC...
forgot to mention the headlamp socket/connectors..those usually corrode.. best replace both headlamps..
200 headlight issues farmallboy91 Cavalier Problem Diagnosis 3 07-12-2010 09:08 PM
92 Corolla DX Headlight Issues chrisg000 Corolla/Matrix/Voltz 2 12-28-2004 09:57 PM
97 blazer headlight issue tspencer73 Blazer 3 10-06-2004 02:14 AM
Major Major Headlight Issues. Your A Geneious If U Know... Djs87 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 16 06-14-2004 09:40 PM
93 Ford Escort Headlight issues! HPDOFNTX Escort 3 05-19-2004 02:11 PM
