Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 05-06-2011, 12:09 PM
T.Raphael T.Raphael is offline
2001 Lincoln Ls won't start
I need a mechanics advice or suggestion. I have a 2001 Lincoln Ls V8 3.9L I was driving soon after filling my gas tank halfway and within 5minutes the car stop receiving power slowed down and shut off. At first I figured bad gas and added a fuel cleaner which did nothing. I have changed the fuel filter and main fuel pump all 8 spark plugs and have checked all emissions coils. I'm out of answers for what the issue may be other then that it's minor because the vehicle would still start but immediately shuts back off without any misfiring. Any suggestions would be greatly appreciated. Thanks in advance.
Old 05-06-2011, 01:50 PM
joegr joegr is offline
Re: 2001 Lincoln Ls won't start
A good suspect for your symptoms (sudden stall + starts and dies instantly) is the MAF sensor. This is exactly what happened to me when a bug got on the sensor (the air filter box wasn't tightly closed).
I think that you can test for this by unplugging the MAF sensor electrical connector. If you do this and the engine will start and run (you'll get a check engine light), then you can try cleaning or replacing the MAF sensor.
The Following User Says Thank You to joegr For This Useful Post:
T.Raphael (05-23-2011)
Old 05-23-2011, 02:04 PM
I have now tried testing the MAF sensor and that did not work. I then also changed the vacuum port switch and the crankshaft position sensors and the car still will not start. I'm unsure of anything else that could be the issue to try and check any help is greatly appreciated.
Old 05-23-2011, 02:50 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
What are the chances you have access to either a scan tool with datastream mode or a handheld oscilloscope?
-Rod
Old 05-23-2011, 02:54 PM
So, does it fire at all or not? If not, try spraying some starter fluid into the airbox while cranking. If that causes it to fire some and run a second or three, you probably have a fuel delivery problem. In that case, the fuel pump would be a good suspect (also check the inertial switch, fuse, and fuel pump relay).
Also, I seen a number of gen I LSes now with faulty PCM relays. So, you might try swapping that one out too. (Note that if it's the PCM relay, your PATS light should be flashing when you try to start the car.)
Old 05-23-2011, 03:29 PM
I have put it to a scan tool and it comes up with 3 codes. No DTC definition code 1 is c1676
code 2 b1805
code 3 u1262.
Also i have already tried using quick start yet it will not start and i have also checked and changed all bad fuses.
Old 05-06-2012, 06:32 PM
Atlas111 Atlas111 is offline
Did anyone ever find out what exactly these codes mean? I just got a 2001 Lincoln LS v6 3.0 and i have the exact same codes. The difference is mine will actually run but in very poor condition. Its seems like its missing really bad but i wanted to check the codes before hand because I know to replace the coils is somewhat expensive. Also, the oil light comes on after being driven a short distance- maybe 3-4 miles. Any help would be greatly appreciated.
Old 05-06-2012, 06:55 PM
FishFind FishFind is offline
One Hot Shot
U1262: SCP (J1850) Communication Bus Fault
B1805 Lamp Turn Signal Rear Output Circuit Short To Ground
A "C" code means a chassis code not related to "P" codes powertrain. So the C code not a misfire or trans issue.
Old 05-06-2012, 07:05 PM
thanks. i appreciate it. now to figure out what the crap i gotta do about it lol
Old 05-06-2012, 07:56 PM
One Hot Shot
you can always call a ford dealer and ask the service department about the codes as well
93 Lincoln Town Car - Cold Start and Cold Run Issues blogsdon Town Car 1 08-14-2009 12:00 PM
91 Lincoln TownCar Signature Series - No power 91lincoln Town Car 7 04-22-2009 11:46 AM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
2001 GTP won't start/ fuel gauge crazy debbyd1954 Grand Prix 1 02-02-2004 05:30 PM
2001 Tahoe won't start after turning off engine brewtahoe C/K 4 12-14-2003 08:37 PM
