Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-06-2011, 09:01 AM
camaro10 camaro10 is offline
1998 Eclipse GS p1776 HELP
I know its the solenoid switch stuck in l/r position i was wondering what that means?
I'm stuck in limp mode can do a key cycle then it shifts perfectly fine.
Things Ive already replaced:
TCU (turned off check engine light)
Input and output speed sensor (old output had metal shavings on it afterwards shifted good for 15 minutes then a rough downshift to 2nd and stuck in limp mode once again)
It was also throwing a p0700 code but now there are no codes any help would be much appreciated I have tried another shift solenoid pack but it was used and didnt do much good it shifted maybe 5 minutes then computer caught on please i need help
Old 05-08-2011, 03:15 PM
Re: 1998 Eclipse GS p1776 HELP
Wow no one at all? come on i seriously need some help!
Old 05-09-2011, 09:32 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
I wish I could offer you some help, but my knowledge of the automatics is very limited unfortunately... A quick look of that p0700 code points to a speed sensor being the problem but you say you have swapped it already... Have you verified with a multimeter that the wiring is ok for the speed sensor? Perhaps there is a bad ground there even?
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 05-09-2011, 09:34 AM
After a little more research of the code, it also indicates that there are trouble codes on the TCU that can be pulled and read as well. Any chance you can get those codes also, so we can better determine where the problem is?
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
1998 Eclipse 4cyl. Non-Turbo...Going Limp...Please Help! :( ClearwaterEclipse Engine, Transmission and Drivetrain 1 09-14-2009 05:42 PM
1998 mitsubishi eclipse rs flywheel question E. Frank Engine, Transmission and Drivetrain 4 08-22-2009 11:38 AM
1998 Eclipse... No spark... HELP!!! chadfowler2005 Eclipse Problem Diagnosis 0 08-04-2009 08:27 PM
p0700/p1776 Help please fancyncarl Intrepid 2 06-11-2007 03:56 PM
1998 Eclipse RS, ENGINE HELP acoustic-sounds Eclipse Problem Diagnosis 3 04-11-2005 11:27 AM
