Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-05-2005, 05:01 PM
acoustic-sounds acoustic-sounds is offline
1998 Eclipse RS, ENGINE HELP
My 420a motor runs rough and white smoke out exhuast after start-up. Does any-one know a possible cuase, give a hole bunch of cuases. This started to happen after a head-gasket change.
Old 04-05-2005, 06:39 PM
Gsx_hooptie Gsx_hooptie is offline
It's good to realize what precipitated the symptoms, since the shit you change is usually the first place to look for a problem.
White smoke could be coolant, which you could be burning because the headgasket you just changed is screwed, because the bolts weren't torqued with the correct sequence or the head was slightly warped from being overheated when the first hg went. The fact your car isn't running well, that you see white smoke from the tail, and that you recently changed the hg would support this hypothesis, but it isn't necessarily so. Do compression and leakdown tests to be sure.
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
Old 04-10-2005, 09:56 AM
Scrappy5885 Scrappy5885 is offline
Send a message via AIM to Scrappy5885
Re: 1998 Eclipse RS, ENGINE HELP
most likly a head gasket problem if it is white smoke
scrap disal
Old 04-11-2005, 11:27 AM
drewh4386's Avatar
drewh4386 drewh4386 is offline
Send a message via AIM to drewh4386 Send a message via MSN to drewh4386 Send a message via Yahoo to drewh4386
if possible change your oil also.
....It has been a LONG time...I want to move to FL or Japan.....
