Old 05-05-2011, 09:25 PM
tmwr2006 tmwr2006 is offline
Question 05 GTP Issues...
I have an 05 GTP with 142,000 miles. More than 50% of the time when I start my car I have to press the gas to get it to start (as if it weren't fuel injected). I have already tried injector cleaner and fuel system cleaner. I burn nothing but Premium gas.
Yesterday, my SES light came on and the car started sputtering and running really rough and feels like it will die out when I start accelerating so I let off the gas and it eventually normals out. Once it normals out it won't do it again until I am sitting and idling for a few minutes.
It is giving codes P0134 and P0135 which would imply that my O2 sensors are bad.
Does this make sense to anybody?
Fuel pressure regulator and O2 sensors??
Someone... please help... Please...
Old 05-06-2011, 05:05 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 05 GTP Issues...
It sounds like its dumping fuel, or you aren't properly burning fuel.
On a fuel injected car holding the throttle open while starting actually clears out fuel. If you flood it you are supposed to hold the throttle open and it will not start spraying fuel until it actually starts.
Old 05-06-2011, 11:52 AM
What could be causing that?
Old 05-06-2011, 06:54 PM
Stealthee's Avatar
Well it could be the o2's. Or the o2's might just be freaking out because they are fuel soaked. Might also be the fuel pressure regulator is being bypassed somehow.
Old 05-07-2011, 09:17 AM
rickisrad rickisrad is offline
did you clean out your throttle body? They are very prone to carbon build up causing it to stall out alot especially when first starting. clean it out well, I use the valvoline throttle body spray, a microfiber cloth to get the bulk of the carbon out, then a bunch of q tips to get every crevice. also change out your pcv valve, cheap and easy. use rtv for the gasket unless the dealer has one in stock.
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
Old 05-18-2011, 01:53 PM
Thanks for the advice.
I have tried the cleaner and it gets better. But it seems like no matter how much cleaning I do it still has the issues after a few days.
When I start it sometimes it seems like its a lawn mower when you don't prime it enough to get enough gas in it to start.
Any of that sound familiar?
Old 05-18-2011, 07:03 PM
definately sounds like a fuel issue, regulator or pump.
did you just use the pour in injector cleaner or actually get in and clean the throttle plate?
Old 05-18-2011, 10:54 PM
How do I clean my throttle plates?
I don't know if i mentioned that the o2 sensors actually fixed the codes but I am still having that issue starting.
Old 05-21-2011, 08:30 PM
disconnect the air duct from the throttle body. you should be able to look inside the throttle body and see a butterfly plate. push open the throttle plate by hand and use the plastic end of a screw driver to hold it open. you should see all of the carbon build up around the plate and in the bore. I use valvoline throttle body cleaner but most others will do fine. spray liberally around all of the carbon, use some q-tips to agitate the stubborn stuff and use a microfiber cloth to wipe clean, repeat until shiny. you will also want to get some maf cleaner and clean the maf very well also. I will see if there is a write up on this in the tip section, if not I will do one tomorrow with some pictures.
The Following User Says Thank You to rickisrad For This Useful Post:
tmwr2006 (05-31-2011)
Old 05-31-2011, 12:58 PM
Thanks for your help. I cleaned the throttle body and the MAF sensor. Now the car starts right up no problem!
Thanks again!
Old 05-31-2011, 04:12 PM
Thanks again!
Not a problem.... That is what we are here for.
GTP issues scuddigi_687@yahoo Grand Prix 7 04-13-2010 09:15 PM
2000 GTP issue with Coolant Temp Sensor tblake Grand Prix 2 06-03-2009 06:48 PM
GTP Anti-Freeze Leak bbaker1985 Grand Prix 2 04-03-2009 05:35 PM
GTP Question Please Help bbaker1985 Grand Prix 6 03-27-2009 04:16 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 08:04 AM
