Old 04-12-2010, 11:13 PM
scuddigi_687@yahoo scuddigi_687@yahoo is offline
GTP issues
Hello folks I own a 2003 Pontiac Grand Prix GTP, I 've done a few mods to this car, 3.4 pulley, k/n coldair intake,and u bend delete. Problem 1: I need a good wheel bearing company I replace the same side passenger front every 3 months I also ride 20's but that is only in the summer and the damn light comes on during the time I ride factories. Problem 2: I done waterpumps before but never this type I'm a big dude 6ft1 320 will my arms fit comfortably in this tight spot it's gonna need changed asap, Problem3:what spark plug is recommended the factory is Ac Delcoc platinum I think but I'm told to use autolites which ones and how do I get the back three! Problem 4: this damn transmission, I had this thing replaced 3x's in 1 yr! I partially blame AAMCO cause they are ones who"rebuilt it" DON'T GO TO AAMCO FOR ANYTHING FAIR WARNING. My Question for that is is there any external fluid to help protect it besides the regular Dexron Bull#$%! Once again yalls help is deeply appreciated thank you.
Old 04-12-2010, 11:48 PM
doctorhrdware doctorhrdware is offline
Re: GTP issues
For the hub assay I would get a GM replacement. It is going to be a tight fit with big arms same goes for the back three plugs. You can try using a universal joint on the spark plug socket. That will aid in getting the back 3 spark plugs out. On the spark plugs use NGK iridiums plugs. That is what is recommended. Also for the water pump you will need to loosen the power steering pump due to the fact that there is a water pump screw that is behind the power steering pump pulley.
Old 04-13-2010, 12:00 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: GTP issues
Since you have the 3.4" SC pulley you can use the Autolite Copper Core Spark plugs. Either the 605 (one range colder) or 104 ( two colder). Thats all I use in my GTP which is moderately modded.
What brand hubs are you using? Also, depending on the year the axle nut torque value varies so that may be a factor.
Timeslip 08/12/06
AF Community Guidelines
Old 04-13-2010, 12:05 AM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: GTP issues
Originally Posted by doctorhrdware View Post
On the spark plugs use NDK iridiums plugs.
i dont know, since he's running a 3.4 if your going to go with NGK i would recommend the TR55's, or as Bob suggested the Autolite 605's since they are a colder plug
i would also strongly recommend getting your car tuned, or at lease getting a PCM. From your list of mods...you do not have the supporting mods to be running a 3.4. just my
Old 04-13-2010, 12:15 AM
Re: GTP issues
I forgot that you have to use a colder plug when using a 3.4" SC pulley. I should be given some demerit points for not remembering to use colder plugs.
Old 04-13-2010, 12:20 AM
BNaylor's Avatar
Re: GTP issues
The following NGK spark plugs match the stock heat range.
TR55
G-Power TR55GP
Laser Platinum PTR4B-15
OE Laser Iridium ITR4A15
Iridium IX TR55IX
AC Delco and NGK do have colder range Iridium plugs you can use. However, best to run a check for knock retard (KR) first before swapping out plugs.
Timeslip 08/12/06
Old 04-13-2010, 09:03 PM
Re: GTP issues
Hey gradprix00 what is a pcm
Old 04-13-2010, 09:15 PM
Re: GTP issues
see link for an example
https://www.zzperformance.com/grand_...=182&catid=107
