Old 05-05-2011, 04:13 PM
luapsided luapsided is offline
Wink 90 Grand Prix 3.1 help!
Well first things first. Car has been running a little rough as of late. As I was changing the plugs, I noticed a vacuum line was off, I think. Maybe it fell off as I was tilting the engine forward but not sure. Still runs rough though so thats besides the point. New plugs and wires, fuel filter, PCV were recent new part put on. Also, last summer I put on a ready fit catalytic converter. Just had to splice it in, but ran just fine after that. I took it to Oreilly's auto and borrowed their OBDI and found no codes.
When its at idle in park, it runs ok, seems like the exhaust has a little jitter in it. Car in drive with the break on, definitely more jittery and would stall out sometimes. Hasn't really stalled out now that I put that vacuum line on but I also put it in neutral at stop lights to prevent this so maybe it would still stall out, who knows.(If it does stall, it fires right back up) Taking off, it seems to take off just great, unless I very slowly accelerate, then it has a little jerking (hesitation) that occurs. Also, when Im at cruising speed (35 mph) and hold the gas steady, thats when I notice jerking as well. Nothing too fierce but theres definitely some 'bogging' out. I really don't know where to start being that there are no codes thrown. I have some oil leak thats over by the belt system and not sure if thats effecting anything. I know the belt gets oil on it as it splatters a line on the firewall after awhile. (sort of like a line mud on your back when you go through a puddle on a bike). Other than that, thats all I got. I really hope someone has an idea.. Thank you!
Old 05-06-2011, 09:51 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 90 Grand Prix 3.1 help!
ohm check the injectors. look for right around 12ohms each. anything less and it needs to be replaced.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 05-06-2011, 12:03 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with Tim. It sounds like you have an injector or 2 going bad since it's kinda random and more prevalent when at steady speed or light accel.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
1997 grand prix anti-theft system components Konstantin Grand Prix 8 10-13-2010 11:20 AM
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 09:57 AM
1992 Grand Prix 3.1 Help Please educated_rage Grand Prix 2 06-19-2008 07:53 PM
1994 grand prix 3.1 Manifold Gasket Leaking, help!! pinkbumblebee Grand Prix 11 05-13-2007 09:22 PM
Help 1994 Grand Prix 3.1 sedan master cylinder problems?? (antilock breaks) kenpo2 Grand Prix 2 01-24-2004 11:05 PM
