Old 05-04-2011, 09:09 PM
guitarfish's Avatar
guitarfish guitarfish is offline
Removing rear caliper on '08
Well, I have to take the rear brake caliper off my 2008 Prix. When I put the E Brake on, then release, the caliper doesn't completely release. I've sprayed it with lubricant several times, it worked a little better for a few days, but it's sticking again.
Questions:
-When I remove the brake line, what can I use to plug the line so fluid doesn't leak out?
-Any ideas how to get the E brake cable off the caliper?
I'm hoping that once I get the caliper off, I can figure out what's causing the sticking and somehow correct it. Otherwise I make need a replacement caliper.
Thanks in advance for help!
Current Grand Prix
2008 GP - 174,000
Former Grand Prix's
1994 GP SE - 231,000
1997 GP GT - 134,000
1998 GP GT - 225,000
2002 GP GT - 222,000
Old 05-04-2011, 10:44 PM
dondeere dondeere is offline
Re: Removing rear caliper on '08
Sounds like your brake cables going bad. If both rears stick or drag I would be checking the first cable from the park brake peddle. Calipers on a 2008 GM shouldn't need replacing yet. I have a 2000 and 2003 Buick with all original calipers. A lot of salt used on pavement in Ontario, and I also travel couple miles of gravel/dirt/mud road every day.
Old 06-07-2011, 08:00 PM
guitarfish's Avatar
I was able to replace my failed caliper. I wrote up some instructions:
2004 & Up Grand Prix – How to diagnose a stuck rear parking brake, and replace caliper
Current Grand Prix
2008 GP - 174,000
Former Grand Prix's
Old 06-07-2011, 08:26 PM
Good Job guitarfish
98 Ultra Rear Caliper Removal cpj Park Avenue 2 04-13-2009 07:08 PM
removing rear calipers help lincoln ls 2002 dss56 LS | MKZ 5 11-11-2006 04:02 PM
Replacing Rear Calipers On 98 GMC Jimmy 4x4 rear disc CanukGMC Jimmy 6 05-07-2006 12:04 AM
