Old 05-04-2011, 06:27 PM
TexasAngel69 TexasAngel69 is offline
Question remote wire hookup on my amp
this has probably been asked and answered but i need help
i have a duel stereo and a vr3 amp i have it all hooked up and the remote run to the amp from the stereo but heres the prob to make the amp power on i had to run a jumper wire from the remote spot to the hot power spot on the amp to get power i know that cant be good so where else can i get power from for the remote wire to work ive never had this prob before and ive used this amp before with other stereos
Old 05-05-2011, 06:00 AM
snshddog snshddog is offline
Re: remote wire hookup on my amp
The way I read this question is the remote wire from the head unit (deck) is run to the remote on the amp and also the positive battery supply terminal. There is not enough amperage in the remote wire to run the amp properly. The "hot power" is intended as a fused run straight from the battery. The size of the fuse and the guage of the wire is determined on what amp you have.
Old 05-05-2011, 06:42 AM
i bought an amp kit and all remote wires are the same gauge ive never had to use anything else with it this is the first time i have had to jump it off the power to make it work ill try a dif size remote wire to see if it will work
Old 05-05-2011, 07:29 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
No, he/she is saying that the power wire from the battery is connected but the auto turn-on lead is not turning the amp on so the power to the turn on is coming from main power wire.
This will mean that the amp is on all the time, not a good solution. See if the turm on wire from the cd player is actually getting voltage. Remember to connect it to the wire on the cd player that blue WITH A WHITE STRIPE, the solid blue one is for the auto antenna. If you are not getting power from the auto turn on wire, check it at the cd player, if the output is bad connect the wire going to the amp to the red wire that gets power only when the ignition is on. That will mean the amp will turn off when the car does.
remote wire on amp and trouble with subs boggess Ranger | Courier 7 06-26-2006 03:38 PM
WHERE? remote wire for amp in a 2003 the vinyl frontier Blazer 7 03-07-2006 11:29 AM
amp is on without remote wire? really wierd tran_nsx Car Audio 1 08-05-2003 09:25 PM
Remote Wire For Amp XeUz Sentra | 200SX (USDM FWD) 6 07-03-2002 11:46 PM
Radio power wire for amp remote.... SilverY2KCivic Car Audio 2 03-19-2002 08:27 PM
