Old 03-05-2006, 05:08 PM
the vinyl frontier the vinyl frontier is offline
WHERE? remote wire for amp in a 2003
2003 Blazer with factory radio, Installing amp & sub, have run power/ground wires and signal wires.
Need to know where to patch in for the remote wire to power-on the amp. The fuse box is hard to reach and not sure about using radio harness. Anyone with prior experience on installing an amp in a 2003 Blazer with factory head unit please advise. Many thanks!
Old 03-05-2006, 06:27 PM
mike1224's Avatar
mike1224 mike1224 is offline
Send a message via AIM to mike1224 Send a message via MSN to mike1224 Send a message via Yahoo to mike1224
Re: WHERE? remote wire for amp in a 2003
you're going to have to tap into the power.. Its been a long tine since i messed with my amp, ant i believe its RED. thats the one that should turn power off the amp along with the stereo.
2002 Chevy S-10 ZR2
Originally Posted by balls_to_the_wall
Some people are alive only because its illegal to kill them.
Old 03-06-2006, 08:48 AM
Teal95Jimmy's Avatar
Teal95Jimmy Teal95Jimmy is offline
Send a message via AIM to Teal95Jimmy
I think you can use any wire that is hot when the ignition is on. Remember this is a remote turn on, so it is only turning on the relay and it will not require much current draw.
Old 03-06-2006, 11:04 AM
the87hyper's Avatar
the87hyper the87hyper is offline
Send a message via AIM to the87hyper Send a message via Yahoo to the87hyper
Correct, you may use any wire that has 12V when the key is in the accessory position. Be sure to turn the key off an make sure the 12V dissappears as well though. 100% correct there is minimal current draw, this is only a signal wire. Make sure your amp is grounded well though.
1999 BLAZER ZR2
KENWOOD HEADUNIT KDC-415S
KENWOOD PS-150 AMP
JL AUDIO 10W6
BOSE SPEAKERS 6X9, 4X6
PARNELLI JONES DIRT GRIP 31 X 10.5 X 15
K&N FIPK COLD AIR INTAKE
APC CARBON FIBER TAIL LIGHTS
Old 03-06-2006, 01:35 PM
Hunter1 Hunter1 is offline
Some line-level converters have this built in so you don't have to splice. Besides you will need them for RCA jacks.
Old 03-06-2006, 07:47 PM
JC327's Avatar
JC327 JC327 is offline
The radio harness on a 2003 does not actually have a an accessory function. Odd way they do it, and it creates headaches for the aftermarket with expensive modules required to emulate the switched power and take over other functions such as the door chime. Anyway, you will want to either tap into an accessory fuse or the main accessory wire at the steering column, which should be a heavy orange wire.
Old 03-07-2006, 08:38 AM
RJ MALIBU's Avatar
RJ MALIBU RJ MALIBU is offline
Just a little info for ya there are vents in the back of the truck that rattle very loud when bass is up. take off covers off and put a little dynamat on the inside of the vent flaps just enuf so they are open a bit and dont rattle, the space created will allow full functionality of vents and no loud a#$ rattlingalso dynamat the tailgate,also vibrates annoyingly
1997 Blazer w/99+front end with clear Euro Projector Headlights and parkinglights and cai 2 -12'' Dual subs 600w RMS 600 watt kenwood amp Sony head unit
2003 malibu-bone stock(wife's car)
Old 03-07-2006, 11:29 AM
OffRoadSonoma's Avatar
OffRoadSonoma OffRoadSonoma is offline
Send a message via AIM to OffRoadSonoma Send a message via Yahoo to OffRoadSonoma
What I've done with all my stereo installs is put an on/off interrupter switch in the remote wire. That way you can turn the amp off when ever you like. Say you get pulled over for your stereo and a cop is trying to write you a ticket you can turn the switch off and say yours doesn't work if he sees it. And when he says you're a liar you can turn up your radio and say see sir, it wasn't me. So far I've been pulled over once for my subs and that worked. So hopefully you never need it, but it is always nice.
