Old 08-05-2003, 06:07 PM
tran_nsx's Avatar
tran_nsx tran_nsx is offline
Question amp is on without remote wire? really wierd
i own a 92 integra ls and in my trunk i have a pioneer amp powering 3 10w0 jl subs in a vantage box. have no clue how long this been happening, but for some reason my amp is on all the time even when i pull out the remote wire. that is really wierd, whats going on? for some reason the power wire is turning it on and that shouldn't be possible. i do know how to install audio equipment but this has stump me. never have i seen this b4. any have an idea? right now i unhooked it and remove the box and amp since its draining my battery to where i have to jump it every time i want to start my car.
Old 08-05-2003, 09:25 PM
Streetwise's Avatar
Streetwise Streetwise is offline
Send a message via Yahoo to Streetwise
Check your manual for the amp. Some amps can turn on without a remote turn on by the low level signal from your head unit (the rca's), as long as you have normal 12 volts of course. Throw me a model number and I'll check it out for you. I would consider checking things through from top to bottom. Your battery should not be drained unless you bump it with the car off. An amp can drain a battery quick if the car is not running.
AMP/Speaker wiring in cooler boom box Chupacabra111 Car Audio 6 12-20-2010 05:29 PM
Remote Wire fpr aftermarket amp beano_brady LS | MKZ 3 12-04-2006 09:49 PM
remote wire on amp and trouble with subs boggess Ranger | Courier 7 06-26-2006 03:38 PM
WHERE? remote wire for amp in a 2003 the vinyl frontier Blazer 7 03-07-2006 11:29 AM
Remote Wire For Amp XeUz Sentra | 200SX (USDM FWD) 6 07-03-2002 11:46 PM
