Old 05-04-2011, 05:19 PM
revyurengine revyurengine is offline
no brakes after lubing slides and pushing pistons back
1997 F-150 , 2 wheel drive , 4.6 triton engine
My father had his RF caliper seize up on him while driving today. Then it seem to free up after rocking the vehicle back and forth, his rim was very hot.
I removed and cleaned his front brakes and sliders, then pushed the dual pistons back into the calipers which seemed to go easily. He then started to pump the brakes to see if they were releasing while I watched and the pistons on both sides only moved out a little , then retracted. They "would not" come back out and squeeze the rotor when he pumped the pedal. (even while engine running)
A local mechanic trouble shot over the phone and said it could be calipers. We changed them with "zero" improvement. We can't even bleed the lines because there's no resistance in the brake pedal at all. Now I'm thinking master cylinder? Any idea how to "bench bleed" them in case we try one?
Dad did say his brake pedal was real low for a few days , then real high and touchy , acting strange.
Any idea how we have no brake pedal pressure now?
Thanks
Old 05-05-2011, 12:22 AM
jyount jyount is offline
Re: no brakes after lubing slides and pushing pistons back
To bench bleed any master cylinder you need adapter fittings first. Then run some preferrably clear tubing from the outputs back into the resevoir and pump the cylinder slowly until you don't see any more bubbles in it. Don't take the lines off until you are ready to reconnect the lines on the truck. The idea is to minimize the amount of air trapped in the lines between the master cylinder and the fluid that is already downstream of it. Also shut the truck off and put the key in your pocket. Bleed brakes without the vehicle on, ALWAYS. pedal will be stiff, so what. Anti-lock braking systems can interfere with bleeding, for that reason never bleed them with it on.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 05-05-2011, 12:24 AM
Also, it is highly suspect that both calipers would seize at the same time. I would say you are on the right track going elsewhere. Hope your calipers weren't to highly priced. Good to replace anyway, but you probably didn't need them.
Current job: RN
Wife's
Old 05-05-2011, 12:35 AM
jackstrr jackstrr is offline
u did put new hoses on didnt u ? also dont push calipers in without bleeder open. you dont want that old crap back into your Mcyl., AND you might damage an internal part with back pressure.
Old 05-05-2011, 08:06 AM
Thanks for the replies guys!
I've been researching a bit and hear about a "rabs" valve" They say it's on the frame rail (i haven't checked yet) and this could be causing our symptoms.
What are the fittings coming out of the master cylinder for the rear brakes? One is about 2 inches long and has a spring inside it. The other larger thing is where the brake line goes from the 2 inch fitting to it, before it goes to the back wheels. It has an electrical plug in to it.
Thanks
Old 05-05-2011, 12:59 PM
I may have fixed it, so far looks good.
We ended up replacing the master cylinder as it wouldn't push any fluid down the lines. I even blocked off the rear line (rear line with the valves and springs etc) and no better.
I bench bled the new master cylinder then installed and bled the front lines for now , we have good brakes now. Will probably bleed the rear soon.....
Thanks for the information!
Kevin
Engine won't crank after intake removal and put back on zachaustin S-10 6 12-04-2005 06:11 PM
after market cams and rods & pistons 4 a SOHC zc HoNdA_eD7 '88 - '91 Civic | CRX | Wagon | Shuttlee 0 10-24-2005 03:18 PM
Brakes-Can't get piston back in caliper sallanblock Pick-Up 17 09-11-2005 07:45 AM
smoking brakes after new rotors and pads stopufool JDM Motor & Parts info/chat 9 09-01-2005 11:52 AM
Engine could not start after turn off and back on DavisT Camry/Camry Hybrid/Vista 15 07-13-2005 02:24 AM
