Old 05-03-2011, 06:11 PM
snorander's Avatar
snorander snorander is offline
Brake pad part help
anyone know what these are called or where I can get them? They go on the ends of the brake pads(2 per pad), for some reason they are missing on mine and I think that is why my brakes are so noisy. Any help would be greatly appreciated! 2001 GMC Jimmy 4X4, front brakes.
Steve
[email protected]
Uploaded with ImageShack.us
Old 05-03-2011, 06:29 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Brake pad part help
It's a "brake wear indicator" AKA Squealer, you can get a set of them in a brake hardware kit from your local parts store for about $10.
Old 05-03-2011, 06:32 PM
old_master's Avatar
Advisor/Moderator
It also keeps the pad from rattling in the bracket. There should be one clip on each end of each pad. After installing them on the pads, clean the slots in the caliper bracket with a wire brush and put some brake lube in the slots, then install the pads.
You have to know how it works,
to figure out why it doesn't.
The Following User Says Thank You to old_master For This Useful Post:
snorander (05-03-2011)
Old 05-03-2011, 07:44 PM
snorander's Avatar
Thanks for the info Blazee. Will do old master!
Steve
New Brake Pads Grinding Rotors HELP williamjay199 Taurus | Taurus Wagon 1 07-13-2009 11:51 AM
Help with front brake pad part number please sharkmonkey Caravan | Voyager 0 07-09-2007 07:35 AM
Which brake pads/parts? mostly_water Metro 2 11-19-2006 02:45 AM
