Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 04-27-2011, 09:36 AM
nandox5 nandox5 is offline
Where does this cable goes?
I had to replace a battery, and when removing it i noticed this cable unplugged?
its for a Chevy venture 98
it also has a check engine light with code p1665, dont know if its related to this.
heres a video of the cable
the black box is the main fuse box thats on top of the battery
http://www.youtube.com/watch?v=m22NfNHDH_Y
Old 04-27-2011, 03:32 PM
scottnhalifax scottnhalifax is offline
Re: Where does this cable goes?
your abs light on? looks like the one for the front passenger abs
2000 safari awd
Old 04-27-2011, 05:43 PM
Stingray11 Stingray11 is offline
That harness does look a lot like the LF speed sensor hanress. Your P1665 code is for the EVAP Vent solenoid control circuit.
David
Old 04-27-2011, 07:24 PM
thanks for the replies
yea, the ABS light is on, but just recently got on, or rather at times its on and off..
any suggetions on where to look so i can check and plug it back in? meanwhile ill try the wheel bearing..
thanks once again..
about the code, where would that valve be located? any suggestions on how to fix it or where/what to look at?
Old 04-29-2011, 10:20 PM
woscarr woscarr is offline
I have the exact same wire on my 98 Trans Sport and 02 Silhouette and on both it's not plugged into anything. I've always wondered what it's for. I figured some option the van didn't come with. Who knows !?
Cheers
Wayne.
Old 04-30-2011, 08:05 AM
the more i think about it, it could be for fog lights as well? does your van have fog lights?
2000 safari awd
Old 04-30-2011, 08:18 AM
Yep both have factory fog lights.
I wonder if it has voltage, and if so.. Switched or not ?
Old 04-30-2011, 11:45 PM
i checked and it seems that the passanger wheel bearing is unplugged!, i put my hand to feel for the connection and it doesnt feel like theres anything connected to the car. ill have to remove the tire just to make sure.
my van doesnt have any fog lights.
Old 07-06-2011, 10:59 AM
bstromb bstromb is offline
That cable goes to the non-existent underhood light. GM used the same harness for all the mini vans, but only the Pontiac and Olds models got the underhood light. I guess they wanted to keep the Chevy owners in the dark.......
Old 07-06-2011, 09:30 PM
broughy84's Avatar
broughy84 broughy84 is offline
My venture had an underhood light.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 07-06-2011, 09:53 PM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
looks like it goes to the air conditioner pump. Does your vans' air conditioner get cold when you turn it on?
That long of a wire coming out of the main harness leads me to believe that it is for the A/C. Which is usually the last engine accessory that the harness has to get to.
where does this plug in to? (pic) tfoti Off-Topic 14 11-21-2004 08:55 AM
Where does this wire go? austin944 Grand Prix 1 06-01-2004 04:35 PM
HELLLLPPP: Where does this WIRE go?? JeremyG 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 3 12-23-2003 05:47 PM
Where does this hose go? Pics inside! Hybrid93Hatch Integra 2 04-11-2003 07:44 AM
