Old 11-17-2004, 01:07 AM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
where does this plug in to? (pic)
after dropping in a new cylinder head i found this little harness with no home and i can't find where it goes...its on a 1990 talon tsi:
if the image doesn't load then here the link to it:
http://www2.freepichosting.com/Images/421552962/5.jpg
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 11-18-2004, 02:10 AM
o*HeR()'s Avatar
o*HeR() o*HeR() is offline
Banned
Re: where does this plug in to? (pic)
might be for a sensor but im not sure
Old 11-18-2004, 04:33 AM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
i got a 98,,that looks like the plug on the back of my intake manifold,try that but i think you would have noticed it,so im not sure
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 11-18-2004, 05:15 AM
kjewer1 kjewer1 is offline
AF - Advisor
Hard to say, but I'll put money on knock sesnor. If you already have that plugged in let me know, and I'll think of the next most likely thing. Looks like KS to me though.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-18-2004, 08:39 AM
RSLaser RSLaser is offline
When i get home ill look at my car to be sure but that seems like a fuse. doesnt really connect to anything.
1991 Plymouth Laser RS
Only sat for a few years....
Old 11-18-2004, 09:35 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Re: where does this plug in to? (pic)
i just put a motor in a 90 laser and i remember seeing that, exact same colors and all, ran right to the knock sensor. also if you do not use the manifold support that runs to the block you must take the sensor off that and mount it to the firewall, its some sort of ground and it fucked with some electrical shit when we started the car, so we just had to ground it out and it was fine.
Old 11-18-2004, 11:29 AM
Testiklees
thanks guys, when pulling the cylinder head i never remembered seeing this wire not being used. and i am using the support bracket...the car starts and runs good without whatever it is connected, but i'll go take a look and see if its the knock sensor
thanks for the help!!
Tim
1990 Talon AWD
PTE SCM5031
Old 11-18-2004, 11:32 AM
Testiklees
also, if this WERE the knock sensor, would it throw a check engine light? mine comes on a few seconds after start up
Tim
1990 Talon AWD
PTE SCM5031
Old 11-18-2004, 05:28 PM
Testiklees
ok, it was the knock sensor. the other end was hanging way down where i couldn't see if, i just felt around for awhile and found it, good call guys
Tim
1990 Talon AWD
PTE SCM5031
Old 11-19-2004, 10:31 AM
AF - Advisor
Sweet.
To answer the last question, I dont think it throws a CEL, but it will lock timing at some default value, like 3 degrees. I think that is the number, but its been about 4 years since I last thought or heard about it.
Kevin Jewer
Old 11-19-2004, 12:38 PM
Testiklees
well after plugging it back in the check engine light never came on, so i guess it was the cause of that. maybe not directly, but indirectly, if you know what i mean...
Tim
1990 Talon AWD
PTE SCM5031
Old 11-19-2004, 09:16 PM
AF - Advisor
Hey, as long as it works Another successful fix, rock out with your cock out...
Kevin Jewer
Old 11-20-2004, 01:57 AM
EclipseRST's Avatar
Banned
... or hang out with your wang out
Old 11-20-2004, 01:03 PM
Testiklees
stick out with your dick out?
Tim
1990 Talon AWD
PTE SCM5031
Old 11-21-2004, 08:55 AM
AF - Advisor
Jam out with your clam out... Can't forget the ladies.
Kevin Jewer
