Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-26-2011, 08:11 PM
Wickster8 Wickster8 is offline
Exclamation 2002 Bonniville will not start
My 02 boniville sle will no start. turn key all electrical comes on including fuel pump but the car will not turn over.
Old 04-26-2011, 08:46 PM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Re: 2002 Bonniville will not start
Only thing I could think of is to see if you have power at the starter when the key is in the crank position. May be the starter solenoid if there is no power coming out of it, or could be a fuse if there is no power coming into the solenoid. A simple 12 volt light tester should be able to indicate the presence of power at either of those points.
Old 04-27-2011, 05:38 PM
Stingray11 Stingray11 is offline
There are a lot of possibilities with a no start. But the first one that I would guess at is either the starter is bad or the VATS wiring from the ignition cylinder is broken.
David
Old 04-27-2011, 06:48 PM
maxwedge maxwedge is offline
A990 racer
Security stay on?
Old 04-27-2011, 07:58 PM
Jrs3800 Jrs3800 is offline
Like the post above... What does the security light do?
Could be everything from the ignition lock, to the BCM right down to the starter its self...
2002 impala will not start polarisxcr Impala | Impala SS 15 11-15-2006 08:23 AM
HELP!!! 2002 TB will not start Splcrguy TrailBlazer | Trailblazer EXT 6 08-21-2006 03:10 PM
2002 engine will not start derhahn Intrigue 4 08-07-2006 07:34 AM
2002 Taurus will not Start! T-Bird Taurus | Taurus Wagon 6 06-07-2006 05:20 AM
Help! 2002 Impala will not start!!!!! sunshine1967 Impala | Impala SS 6 11-23-2004 01:10 PM
