Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 04-04-2004, 12:55 PM
sunshine1967 sunshine1967 is offline
Unhappy Help! 2002 Impala will not start!!!!!
My father just recently purchased a used 2002 Impala. He purchased it in Sept. 2003 with 53,000 miles on it. Over the winter months, he has only driven it probably once or twice a month. Last fall, he replaced the battery thinking that was the problem. Now the new battery appears to be completely charged but no connection when the switch is turned over. Has anyone had the same problem? I'm wondering if this is the same problem that they are having with the 2001 Impala?
Old 04-04-2004, 11:22 PM
jay hullett jay hullett is offline
Re: Help! 2002 Impala will not start!!!!!
check to see if security lite is on or flashing after trying to start, if so passkey switch may b at fault
Old 04-10-2004, 07:07 AM
WGP WGP is offline
As Jay said if the theft system light is flashing (or on steady), leave the Key ON and wait 10 minutes. If the light is flashing it should stop after 10 minutes and the pass-lock will be reset. Turn off the ignition and try to start. I had this problem with my 01 Malibu. It turned out to be the pass-lock sensor on the ignition switch. (just traded the Malibu for an 04 Impala)
Old 04-17-2004, 11:34 PM
dizzix's Avatar
dizzix dizzix is offline
Send a message via MSN to dizzix Send a message via Yahoo to dizzix
does anyone know how to bypass the passlock system....
Old 04-19-2004, 05:21 PM
WGP WGP is offline
BypassKit ( www.bypasskit.com ) makes a product that will temporarily bypass the passlock for a remote starter to work. I sent them an email when I was having trouble with my Malibu and asked if their kit could be used to permanently turn off the passlock but they didn’t respond. I didn’t pursue it any further but it maybe it's still a possibility.
Old 04-19-2004, 10:19 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Re: Help! 2002 Impala will not start!!!!!
No, the bypasses will not work. I should know, I install remote starts all the time. The problem you are facing is a faulty Passlock transponder and the only fix is to have the complete system replaced.
Old 11-23-2004, 01:10 PM
Shadetreeme's Avatar
Shadetreeme Shadetreeme is offline
Thumbs up Thank you!
WGP
Thank you.
Your experience and knowledge worked great!
(My 02 Imp. didn't want to start).
2002 B3000 will not start, there is fuel spark and compression. mac2143 B-Series/Bravo/Bounty/Drifter 1 04-08-2007 11:02 AM
2002 impala will not start polarisxcr Impala | Impala SS 15 11-15-2006 08:23 AM
HELP!!! 2002 TB will not start Splcrguy TrailBlazer | Trailblazer EXT 6 08-21-2006 03:10 PM
2002 engine will not start derhahn Intrigue 4 08-07-2006 07:34 AM
2002 Taurus will not Start! T-Bird Taurus | Taurus Wagon 6 06-07-2006 05:20 AM
