Old 04-26-2011, 10:07 AM
ryanusrey2012 ryanusrey2012 is offline
1995 Blazer flooding bank 2
can anyone help me i have a 95 blazer where cylinders 2,4,6 do not fire but they do have spark and fuel is it the spider assembly or could it be out of time
Old 04-26-2011, 11:45 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 95 Chevy Blazer
Welcome to AF.
For help.
With a problem on yours it is best to find the New thread/post button and start your own thread.
Give all info on it.
Engine code and mileage and what you have done or not done so far.
What is your fuel pressure reading?
Will it run on the road?
Missing on the road?
What is the engine vacuum reading?
Have you checked for a stuck open EGR valve?
Have you checked compression and dist cap and rotor?
Is the plugs wet or dry on the firing ends?
Any codes or check engine light?
MT
Old 04-26-2011, 02:10 PM
Re: 95 Chevy Blazer
well the plugs are wet and it is the W code engine i do not have a fuel pressure or a vacuum pressure gage but it has fuel and spark the it will drive down the road but it will run rough and have no power till it gets to about 3rd gear and then you feel more power the engine light is on but i have not seen any code when i cycle the key. it is flooding the passenger side bank of the engine
Old 04-26-2011, 04:42 PM
MT-2500's Avatar
AF - Advisor
Re: 95 Chevy Blazer
OBD11 0r 94-1/2 t0 95
If check engine light is on you need to get codes with a scanner and post back code no.
And then clear codes and see if Any comes back.
If older OBD 1 you can jump pin A & B and read light flashes for codes.
Just fuel or close in horse shoes does not count for much.
GM 4.3 has to have full and pressure up to specs to run right.
We need all fuel pressure readings and engine vacuum readings.
If rough/missing on idle and runs good higher speeds on road.
You may have a stuck open egr valve or a bad vacuum leak
Check egr valve for stuck open or carbon ball under plunger and PCV and all over intake and all lines for vacuum leaks.
Have you done any work on it or replaced any parts?
Got good ac delco plugs and parts on it.
As in plugs are all wet is that all of them wet oily or gas wet or just on even bank 2-4-6?
IS THERE ANY COOLANT IN ENGINE OIL OR DOES IT SMELL LIKE GAS AND REAL THIN?
MT
Old 04-26-2011, 04:49 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: 1995 Blazer flooding bank 2
Sounds like your fuel pressure regulator is leaking into the plenum.
Old 04-26-2011, 06:04 PM
82Stang 82Stang is offline
That or the plastic fuel lines in the plenim are leaking on one side. They are notorious for leaking in there, running like crap, and setting the engine code. First thing I'd do is open up that plenim, very easy to do, not much to take off.
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
Old 04-27-2011, 09:25 AM
if it is the spider assembly would it have to be replaced or is there a war to repair it i have kinda a tight budget
Old 04-27-2011, 10:12 AM
If it's the FPR, fuel pressure regulator, that's not an expensive part to buy new. If it's the spider assembly, that costs a little bit of $$, so I'd try a junkyard part.
Rodney Dangerfield
Old 04-27-2011, 10:26 AM
MT-2500's Avatar
AF - Advisor
Tight budget is a good reason to do the proper testing first to keep from just throwing parts at it.
Rent or borrow or buy a fuel pressure testing gauge.
A Fast leak down on fuel presure is a good sign of the nut kit fuel lines or pressure regulator is leaking.
If you pull upper intake off prime up fuel pressure to full pressure and look for gas leakage in there.
MT
Old 04-27-2011, 04:45 PM
old_master's Avatar
Advisor/Moderator
I agree with MT2500, remove the plenum, let the pump prime the system and watch for leaks. My guess is you'll find a leaky fuel pressure regulator. If the lines leak, cylinders 1, 3, & 5 will flood. If there's a fuel leak inside the plenum, the oil will be contaminated with fuel. After the repair, make sure you change the oil & filter. This thread might help you: http://www.automotiveforums.com/vbul...d.php?t=503238
You have to know how it works,
to figure out why it doesn't.
The Following User Says Thank You to old_master For This Useful Post:
ryanusrey2012 (05-02-2011)
Old 04-29-2011, 09:39 AM
uhh yes this sounds very probable but can the FPR cause cylinder #2,4,and 6 to missfire i noticed you said 1,3,5 does it really matter which bank floods or can a bad regulator cause either bank to flood
Old 04-29-2011, 01:12 PM
blazee's Avatar
Problem?
The FPR floods 2, 4, & 6. The internal fuel lines (AKA "Nut Kit") flood 1, 3, & 5.
The Following User Says Thank You to blazee For This Useful Post:
Old 05-02-2011, 09:29 AM
okay i took the plenum off and primed the system to find a low pressure dumping of fuel where the FPR is located but i did notice as well that the drivers side bank that is not defective is covered with a thick black sut and the defective side is clean i can get pictures later on today to show but the most obveious problem is the FPR
The Following User Says Thank You to ryanusrey2012 For This Useful Post:
blazee (05-03-2011)
Old 05-02-2011, 11:29 AM
MT-2500's Avatar
AF - Advisor
The leak will clean thy area where it is leaking.
Fix the leak and you should be good to go.
MT
The Following User Says Thank You to MT-2500 For This Useful Post:
Old 05-02-2011, 12:05 PM
it is definatly leaking from the FPR and has washed the passenger side im going to replace the FPR and see how it works thanks
1995 Jimmy misfires when cold reed92 Problem Diagnosis 11 01-17-2010 09:32 AM
1995 Blazer flooding ravine Problem Diagnosis 4 10-02-2006 12:53 PM
2000 Blazer Floods at Random Kinzua Blazer 3 11-28-2004 03:41 PM
1995 camaro flooding kommish55 Camaro Discussions 14 08-23-2004 11:32 PM
92 S-10 Blazer floods when warm mjfdesigns S-10 7 02-18-2004 10:48 AM
