Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 04-23-2011, 07:19 PM
supercivic86 supercivic86 is offline
stuck drivers side window help
Driver side window was going down fine but would struggle to go up.....now it doesn't work at all. no up or down. could it be the switch or is it the motor in the door? I tried to get to the switches on the dash but couldn't get the panel off. any help would be great! thx
Old 04-24-2011, 01:22 PM
Re: stuck drivers side window help
Come on, 19 people have read the post and no one has any idea of how to get to the window switches on the dash? I've taken out all the screws that i can see and still can't get it off. anyway ....please help!! gf is going nuts not being able to put down the window. she's a spitter and usually misses when she tries to spit it out the passenger side....lol
Old 04-24-2011, 01:35 PM
stanbell stanbell is offline
sounds like a window glide problem or a motor problem, check the wires for power before removing evrything
Old 04-24-2011, 02:09 PM
BullShifter's Avatar
Usually on a CRV it's a window reg/motor issue. You are better off taking the door panel off so you can test for power at the motor while you move the switch. Once the door panel is off unplug the connector and check for power while you move the switch. You can also tap on the motor while moving the switch to see if the window moves. Chances are it will a few times and if this is the case you have confirmed the motor is shot. If I remember right, the last CRV window motor we did was expensive from Honda so we gave the customer of the option of going with an aftermarket one. We ended up getting it from Napa which came 2 ways. Motor only or Motor/reg. The motor and regulator was not much more. .
Old 04-25-2011, 09:04 AM
Copytech99 Copytech99 is offline
^^^ Good info, Also as a test you can apply battery voltage directly to the disconnected motor to see if it will move.
Keep both the upper and lower rubber tracks clean, and make sure the rubber is in the channel near the bottom (I had to tack my 05 Civics rubber into the channel with a spot of glue to make it stay) and also not deformed & binding the glass
'03 Grand Am GT Side Window Replacement CaptAdams35 Grand AM 4 09-28-2011 06:58 PM
automatic locks and driver side window not working rmwilson Problem Diagnosis 5 06-23-2010 08:04 AM
2000 323i Rear Drivers Side Window Problems dereistic 3 Series 0 06-11-2010 05:06 PM
Driver side window help!!! buckeyeguy Grand Prix 4 09-16-2009 08:58 PM
Driver side window operation and washers are out Moonzuk Sierra 0 06-16-2009 09:25 AM
