Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 04-21-2011, 03:40 PM
cadillaction cadillaction is offline
3.9 cuts out when hot---FIXED!
I hope this helps someone.... 1996 Ram Van with a 3.9. Ran sensational when cold/open loop. Once warmed up, it would cut out at times, especially when leaving a stoplight. On the highway it would run great. Followed earlier threads on this and made repairs accordingly. Codes, when I would get one, would be random misfire, 303,305. Fuel pressure, ok. Checked for vacuum leak, none. Cleaned all grounds, changed 3 and 5 plug and wire, no change. Cap and Rotor which it needed, no change. Coil, no change. Ok...maybe crank sensor. Nope. Drove around wiggling every wire loom in sight, no change. Alright, maybe a cam sensor. No change. The only thing left that seemed to be "heat sensitive" was the PCM. Got a junkyard PCM and viola, FIXED! Life is good.
98 z71 cutting out when hot at medium to high rpm muddog32 Sierra 0 06-20-2009 03:23 PM
Chevy 350 cuts out! roknjock2 Chevrolet Classics 3 04-17-2009 07:13 AM
97 Firebird cuts out when engine is hot dakumanchik F-Body Problem Diagnosis 5 04-02-2008 10:31 AM
'92 525i cuts out when hot bmblues 5 Series 0 11-21-2007 06:12 AM
87 cutlass ciera 3. v6 cuts out when warm randymc Cutlass Series 6 09-06-2005 10:34 AM
Tags
engine , intermittent , miss
